visual basic interface and rs232 control
Bluechem
Member level 4
what kind of control, do you want to communicate with another computer, a chip or ... ?
negreponte
Member level 4
I want to control a chip which called PCL841 and it can be found in the web https://www.advantech.com/. The chip receives temperature values
from a boiler and I want to control the chip for example "receive values
every five minutes".
Bluechem
Member level 4
I went to the site and searched for PCL841. PCL841 is a PC interface card which communicates with CAN controllers, it has nothing to do with RS-232. you can use this card to communicate with microcontrollers that have CAN controller. are you a windows programmer I mean do you have Visual Basic programming skills ?
if you want to read temprature every 5 minutes you can happily use RS-232 which is much simpler and cheaper.if you want to use RS-232 you don't need PCL841. having said that, noise level of your environment is also important. how much noise do you have there? and what is the distance between computer and sensor ?
cawan
Full Member level 2
I recommend mscomm object instead of writing your own activeX or dll file. Besides, you can try to have winio.dll to ease your rs-232 application programming.
sdobric
If CAN is a must you can insert some microcontroler with both can an rs232 (some PIC fo example) and do exactly what you want.
proiettile
Junior Member level 2
You can use CreateFile(..), WriteFile(...), ReadFile(...) win32 apis by MSDN and how you can call the apis from VisualBasic
ADM
