Visual Basic - Graphical Interface
wa7ed
Newbie level 5
Hi!
I've worked in a project. It is currently working with the Hyper Terminal (BUT) I want to use Visual Studio instead. Where can I find a clue to start my job?
What I'm looking for is:
How the data or commands are being sent/received between the Microcontroller & the Graphical Interface (PC) ?
can you tell me more specific what do you want?
do you use port paralel/serial..
using USB port, Or RS232??
but that i know is, you must setting your vb project first, if you want to interface your pc with some other device such as microcontroller..
click project-->>component-->>microsoft windows common control
correct me if I wrong...
thx..
andi21
    wa7ed
Visual basic comes with built in activex control for serial port communication. I think it is called MsComm activex control. Refer to the following link for more info.
wa7ed said:
Hi!
you may check this #1261232 code for serial port communication in VB.Net to replace hyper terminal function with VB.NET GUI
regards
bassa
using mscomm activex is always good, as u amy have vb.net tehn u have a flexibility to use the the active x control in ur code
Thanks guys for your help.
Your links are really helpful ..
I got a sample program and i want to understand it well...
Can I ask here about the codes of vb.net?
