Register Log in
Virtual machine programs for using Linux on Windows
anafor
Newbie level 5
You may use Virtualmachine program for using linux on windows
reddie32
Newbie level 2
Re: virtual machine
yes
if you install wmware under windows you can install most linux version and work on it...
I'd install ubuntu, fedora and mandriva on virtual machines on my win xp home... now mac os too... :D
bye
edy
calm
Full Member level 4
virtual machine
yes you can ,try it. virtual machine is a good tool
edacw1
Full Member level 4
virtual machine
VM cannot fit runing large programms.
stiff
Newbie level 5
virtual machine
can You use Virtualmachine program for using unux on windows ?
tieuquaybk
Member level 4
virtual machine
sure! you can use VMware for installing any windows and unix/linux OS. But i think it's for beginning. When you get acquainted with it, you should install dual boot
damunix
Re: virtual machine
there is also VirtualBox, which is opensource and work very well
szaleniec
Newbie level 2
Re: virtual machine
I confirm that VirtualBox is very good VM software. I use both linux host and windows host versions and I've never had any problems.
Shurik
Full Member level 3
virtual machine
Use VMWare on linux best !!!!
It is operating very good !!!
hsf1234
virtual machine
VMware is very good.
R3verseEngin33r
Newbie level 5
andy2000a
Advanced Member level 2
Re: virtual machine
vmware release thinApp (ger this product from inthInstall Corp)
ThinApp package some DLL .. and make Execute software .
but some tool maybe need license file
can be package to signle file , and move to other PC ?
_SquiD_
Re: virtual machine
As tieuquaybk said a Virtual Machine it's a great tool for getting acquainted with different linux distro versions (www.distrowatch.com for all of them) ... you can see which is more appropriate for you ... But the greatest disadvantage is when you are trying to run complex applications ... you will surely need lots of free memory ... and even if you have sufficient you may still realize that it isn't running smoothly. best of luck . :D
Eugen_E
Full Member level 6
Romania
Re: virtual machine
VM is great because you eliminate the need and time loss to reboot, and can run diferent OS in the same time.
I prefer VM on Linux or FreeBSD and WinXP inside VM, with controlled/no internet access to Win. This way Windows runs securely inside *nix OS, though a bit slow.
*nix is a very stable and secure environment, and makes work more secure.
Xen is based on qemu? I used qemu standalone on Linux, it doesn't have full virtualization, but is fun to use.
stevenlee
Member level 2
virtual machine
for virtual, try vmware only, forget the other program.
flanello
Advanced Member level 1
Re: virtual machine
I use VirtualBox, for me its the perfect program.
Toggle Sidebar
