aliasnikhil
- Joined
- Feb 10, 2012
- Messages
- 7
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,354
Hi All,
I need to test a design on ML605 evaluation board (Virtex-6).
The problem I am facing is how do I give input test vectors to the FPGA in real time using my testbench or chipscope or any other way. The design does not have any I/O pins yet because I am yet to debug it. Instead, the input test vectors are stored in a file and not coming from an external source. I need to find a way to send these as inputs to my design.
I know that chipscope can help me monitor the outputs but how do I apply test vectors that are stored on a file? I want my design to work in excess of 100MHz. Even if I use the hardware co-simulation using system generator in MATLAB, the JTAG or even the Ethernet isn't fast enough to send so much data so fast.
I have verified my design using the Simulink plugin "System Generator" in the Hardware Co-simulation environment. But the trouble with that is it works at very slow speeds. I want to test it for high speeds (that being the primary goal/spec) Can I somehow store my test vectors in a memory beforehand and make the circuit accept that as input? Or is there any other way?
Please help!
Thanks
-Nik
Please help!
Thanks
-Nik
