wavescan command
Hm, let me clarify. I'm running the simulation in Cadence (in Linux) through the Analog Environment. Except I'm using the HSPICE simulator instead of Spectre. I was wondering if I can use WaveScan or AWD, which comes with Cadence to view the output of the HSPICE run. The problem is that I can't use AWaves since its not available on Linux. In the Cadence manual under the topic something like "HSPICE Interface Reference" it suggested that you are able to do it by setting the .option flag to SDA=2. Apparently by setting SDA=2 it converts the HSPICE output to WSF format, which I assume (correct me if i'm wrong) can be read by WaveScan. I was wondering if anyone has got this working before?
Thanks again.
