video signal distributor needed
asolondon
Junior Member level 2
Hi, i need an idea and if possible a circuit diagram of a device can aid in distributing video signals from a single video machine to up to like ten television screens. I need it as soon as possible.
opa692
The OPA692 buffer will drive four lines. You can do a two stage tree of these. The data sheet has typical applications.
Analog Devices have a lots IC for video distribution. AD8009 is good and can drive 5 75ohm loads without problems. But the best solution in my opinion is AD8010. It can drive up to 10 loads, and is still available in DIP8 pakage ( easy soldering :) ) .You can buy it from F@rnell.
Elantic has a lot of IC for this case.
video splitter
Hello ,
This simple circuit maybe can help you.
Garfield 8)
As a cheap solution you can use cascaded passive splitter. as splitter is a passive one attenuation will be done, if this attenuation is accepted then keep it, and if not go to an active solution as other friend describe.
Look at:
