PaulHolland
Advanced Member level 2
I want to use a DSP to do some video processing on analog composite PAL and NTSC video, simple processing only what is the best DSP for this ?. Needs to be low cost and have embedded memory for copy protection of dsp code. if possible AD and DA converters for composite video.
I need to sample the video at some 27 MHz, process it and stream it to the DA.
Process is simple, save and store video line and add of change the begin end points.
