vibrator motor circuit
Hai oTaru
You need to construct a pwm circuit which controls the motor speed first and then interface it to a RF remote unit receiver which will control the function wirelessly when specific buttons are pressed. Pwm circuit depends on your motor volatge, and wattage along with the power source. (AC or DC).
These ready to assemble RF remote kits from United7 Technologies may help you:
Both the kits comes with 4 relays for 4 channels with Common, N/c and N/o contacts available through PBT connectors. The motors are requires to be wired in the correct sequence to work as required. The kits comes with complete documentation, schematics, PCB's, required components, and the component layout which helps you to construct and work the kit. More details and other projects may be seen at
www.united77.com/projects.htm
1. RF based 4 channel Remote controller based on “Holtek” En/decoders
This is a remote controller which is widely used in robotic application where in momentary mode, 4 channels are available. Receiver side is equipped with four relays at the out put which can be wired in any configuration for the required operation. Individual addresses can be selected to operate more than one remote kit at a time.
2. Multipurpose Four channel RF Remote with 89C2051 Microcontroller.
This is a remote controller which can be widely used in robotic application when in momentary mode. All the 4 channels can be individually programmed as latched outputs for lighting loads or momentary outputs for bell or any other automation requirement. Receiver side is equipped with four relays at the out put which can be wired in any configuration for the required operation. 4 individual addresses can be selected to operate more than one remote kit at a time.
Good luck
