nathand
Newbie level 1
- Joined
- Jan 5, 2014
- Messages
- 1
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 7
Hi, i'm trying to develop an UART on a Nexys2 board, and I'm desperated.
Here's the piece of code of the receiver. The simulation is ok but then in the board doesn't work with Hyperterminal.
I've been more than a month working with this with no result... Every help is thanked.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity UART_receiver is
port(
CLK, RST : in STD_LOGIC;
Rx : in STD_LOGIC;
s_tick : in STD_LOGIC;
rx_done_tick : out STD_LOGIC;
intData : out STD_LOGIC_VECTOR(7 downto 0);
contando : out STD_LOGIC
end UART_receiver;
architecture Behavioral of UART_receiver is
subtype miInteger is integer range 0 to 20;
type state_type is (idle, start, data, stop);
signal state_reg : state_type;
signal clockCounter : miInteger;
signal bitCounter : miInteger;
begin
process(CLK, RST)
begin
if(RST = '1') then
clockCounter <= 0;
state_reg <= idle;
intData <= (others => '0');
elsif(CLK'EVENT AND CLK = '1') then
case state_reg is
when idle =>
if(Rx = '0') then
clockCounter <= 0;
state_reg <= start;
end if;
when start =>
if(clockCounter >= 7) then
clockCounter <= 0;
bitCounter <= 7;
state_reg <= data;
else
clockCounter <= clockCounter + 1;
end if;
when data =>
if(clockCounter >= 15) then
clockCounter <= 0;
intData(7 - bitCounter) <= Rx;
if(bitCounter = 0) then
state_reg <= stop;
bitCounter <= 7;
else
bitCounter <= bitCounter - 1;
end if;
else
end if;
when stop =>
state_reg <= idle;
else
end if;
end case;
end if;
end process;
end Behavioral;
