shedo
Junior Member level 1
Hi all,
I need to implement an uart module written in vhdl to comunicate with another module, I have tried to use this **broken link removed** (source) with this main:
with this ucf constrain file:
But the result is:
I use tera term with: Baud rate: 115200, 8 bit data,parity none,1 stop bit and flow control: none
I have spartan-6 sp605 and i use xilinx design suite 13.3
Please can you help me?
Thanks Ivan
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity MESSAGE_GEN is
port ( -- General
CLOCK_Y3 : in std_logic;
USER_RESET : in std_logic;
SEND : in STD_LOGIC;
-- UART
USB_RS232_RXD : in std_logic;
USB_RS232_TXD : out std_logic
end MESSAGE_GEN;
architecture RTL of MESSAGE_GEN is
-- Functions
--Type definition
type hello_world_type is array (0 to 4) of integer range 0 to 255;
--Hello world type definition
signal hello_world : hello_world_type := (10,101,108,108,79);
signal state : integer range 0 to 299;
-- Component Declarations
component UART is
generic
BAUD_RATE : positive;
CLOCK_FREQUENCY : positive;
TX_FIFO_DEPTH : positive;
RX_FIFO_DEPTH : positive
port
( -- General
CLOCK : in std_logic;
TX_FIFO_DATA_IN : in std_logic_vector(7 downto 0);
TX_FIFO_DATA_IN_STB : in std_logic;
TX_FIFO_DATA_IN_ACK : out std_logic;
RX_FIFO_DATA_OUT : out std_logic_vector(7 downto 0);
RX_FIFO_DATA_OUT_STB : out std_logic;
RX_FIFO_DATA_OUT_ACK : in std_logic;
RX : in std_logic;
TX : out std_logic
end component UART;
signal CLOCK : std_logic := '0';
signal send1 : std_logic;
signal reset_d0, reset : std_logic := '0';
signal uart_rxd_d0 : std_logic := '0';
signal uart_rxd : std_logic := '0';
signal uart_txd_d0 : std_logic := '0';
signal uart_txd : std_logic := '0';
signal uart_tx_fifo_data_in : std_logic_vector (7 downto 0) := (others => '0');
signal uart_tx_fifo_data_in_stb : std_logic := '0';
signal uart_tx_fifo_data_in_ack : std_logic := '0';
signal uart_rx_fifo_data_in : std_logic_vector (7 downto 0) := (others => '0');
signal uart_rx_fifo_data_in_stb : std_logic := '0';
signal uart_rx_fifo_data_in_ack : std_logic := '0';
-- Messages
constant MSG_CONFIGURED : string := "FPGA con";
begin
CLOCK <= CLOCK_Y3;
DEGLITCHER : process (CLOCK)
begin
if rising_edge(CLOCK) then
reset_d0 <= USER_RESET;
reset <= reset_d0;
uart_rxd_d0 <= USB_RS232_RXD;
uart_rxd <= uart_rxd_d0;
uart_txd_d0 <= uart_txd;
USB_RS232_TXD <= uart_txd_d0;
end if;
end process DEGLITCHER;
UART_inst1 : UART
generic map
BAUD_RATE => 115200,
CLOCK_FREQUENCY => 100000000,
TX_FIFO_DEPTH => 1023,
RX_FIFO_DEPTH => 1023
port map
CLOCK => CLOCK,
RESET => reset,
TX_FIFO_DATA_IN => uart_tx_fifo_data_in,
TX_FIFO_DATA_IN_STB => uart_tx_fifo_data_in_stb,
TX_FIFO_DATA_IN_ACK => uart_tx_fifo_data_in_ack,
RX_FIFO_DATA_OUT => open,
RX_FIFO_DATA_OUT_STB => open,
RX_FIFO_DATA_OUT_ACK => '0',
RX => uart_rxd,
TX => uart_txd
MESSAGE_SENDER : process (CLOCK)
begin
if reset = '1' then
uart_tx_fifo_data_in <= (others => '0');
uart_tx_fifo_data_in_stb <= '0';
state <= 0;
else
if uart_tx_fifo_data_in_ack = '1' then
end if;
if (send='1' and send1='0') then
if uart_tx_fifo_data_in_stb = '0' then
-- Send new line character and go to next state.
uart_tx_fifo_data_in_stb <= '1';
uart_tx_fifo_data_in <= std_logic_vector(to_unsigned(hello_world(state),8));
state <= state+1;
end if;
end if;
send1 <= send;
end if;
end if;
end process MESSAGE_SENDER;
end RTL;
NET "CLOCK_Y3" LOC = AB13;
NET "CLOCK_Y3" TNM_NET = "CLOCK_Y3";
TIMESPEC TS_CLOCK_Y3 = PERIOD "CLOCK_Y3" 100000 KHz;
NET "USER_RESET" LOC = C1;
NET "SEND" LOC = F3;
## 24 on U4
NET "USB_RS232_RXD" LOC = H17;
## 25 on U4
NET "USB_RS232_TXD" LOC = B21;
But the result is:
ÀøÀøÀøÀøÀøÀøÀøÀøÀøÀøÀøÀøÀøÀøÀøÀ
Thanks Ivan
