VHDL tristate buffers
shaiko
Advanced Member level 5
The simplest way I know to describe a tristate buffer is :
io_port <= driver when direction = '1' else 'Z'
But what if I do it in a more complex way - In a registered output FSM for example ?
if rising_edge (clk) then
case state is
when state_1 =>
io_port <= ( others => 'Z' ) ;
registered_io_port <= io_port ;
when state_2 =>
io_port <= driver ;
Will the above FSM code inffer (with guaranteed certainty) a tri-state buffer for "io_port" ?
std_match
Sweden
The basic principle should work, but your code has a potential problem. The code for state_1 will tristate io_port from the current rising_edge, but the registered_io_port will store the value before the current rising_edge. The value you read is valid one clock cycle after you set the output to 'Z'.
shaiko
Sure,
But that's the case with any reistered signal.
Output is good only at the next edge.
TrickyDicky
that wont work, you cannot register a 'z' value. you can however register the enable value that tristates the output.
shaiko
I'm not trying to register the 'Z' value - I want to register the logic level at the "inout" pin when it's tristated...
std_match
Sweden
What you say is that the 'Z' assignment can't be done in a clocked process?
I see nothing wrong if we just see it as VHDL code, but I can understand if synthesis tools can't handle it.
dave9000
Full Member level 2
Precision Synthesis has got no problem with it. I have a working design like this:
In the FSM process:
   when s2 => my_bus_cld <= data_out;
   when s4 => my_bus_cld <= (others => 'Z');
   when s5 => data_in <= my_bus;     -- NOTE: not my_bus_cld
Outside the process:
   my_bus <= my_bus_cld;
my_bus is the inout port. Note that I wait a clock tic before samplig the data.
shaiko
std_match, you say:
"but I can understand if synthesis tools can't handle it" - I don't.
What's wrong with sampling in the logic level of an inout port ?
Can you suggest another way ?
std_match
Sweden
std_match, you say:
The last posts have not been discussing the reading of the port. We are discussing the tristating by setting the port to 'Z' in a clocked process. It isn't a problem for the VHDL language, but a synthesis tool must create at least one extra register for each group of outputs that are tristated together. The special value 'Z' can not be held in the same register as the "normal" value.
FvM
Super Moderator
Staff member
Bochum, Germany
Nothing is wrong, it's just misunderstanding, I presume. You didn't say clearly that io_port is an external pin and registered_io_port an internal signal sampled from this port. I also didn't understand it at first sight.
