VHDL testbench enhancement
paulki
Full Member level 2
Bangalore
Hi folks,
I need a help in enhancing my existing testbench with additional functionality. Want to know whether VHDL allows us to use compiler time defines ? ( like Verilog supports as `includes). If any such options are available please share with me. Appreciate all your inputs.
Thanks,
Paul
Sort of. VHDL has generics (Verilog calls them parameters). For example:
entity test is
  generic
    INST_NAME : string := "Entity one";
    BUS_WIDTH : integer := 32
  port
    cs : in std_logic;
    rd : in std_logic;
    wr : in std_logic;
    data : inout std_logic_vector(BUS_WIDTH-1 downto 0)
end entity test;
You can then set the generics when you instantiate a component. For example:
architecture behav of tb is
  component test is
  generic
  port
    cs : in std_logic;
    rd : in std_logic;
    wr : in std_logic;
  end component test;
begin
  test_inst : test
    generic map
      INST_NAME => "Test Instance #1",
      BUS_WIDTH => 16
    port map
      cs => test_cs,
      rd => test_rd,
      wr => test_wr,
      data => test_data
end architecture behav;
Of course, when instantiating a component, the values you pass to the generic map can come from just about anywhere. For example:
  const TEST_INST_NAME : string := "Test Instance #1";
  signal test_data : std_logic_vector(47 downto 0);
begin
  test_inst : test
    generic map
      INST_NAME => TEST_INST_NAME
      BUS_WIDTH => test_data'length
And you can pass generics into a generic map. For example:
entity tb is
  generic
end entity tb;
begin
  test_inst : test
    generic map
      INST_NAME => "Test Instance",
      BUS_WIDTH => BUS_WIDTH  -- Note that the left hand side is bound to the component and the right hand side is this architecture/entity
The only restriction with generics is that they be statically defined. They cannot be dynamically determined. However, some simulators allow generics to be set at simulation time. If your top level testbench entity has a generic, you may be able to override it at the start of simulation. But once simulation begins, you cannot change that value.
Hope this helps.
