Richard29
Member level 1
Hi all,
I have two nested procedures, where the "main" procedure
makes use of "subproc" to accumulates a result in variables
t0 and t1, which is then returned at the end. This should all
be computed in one clock cycle, and the circuit more or less
just consists of simple logic gates (xor, or, and). When I try
to describe the circuit as below I get the following error:
Acutal (variable t0) for formal "a" is not a signal
That makes sense as the subprocure requires signals as input,
but I wanna pass it a variable during the main procedure. Is
there a simple way to circumvent this problem with casting for
example?
Thanks
example?
Thanks
procedure subproc
signal a : in std_logic_vector(31 downto 0);
signal b : in std_logic_vector(31 downto 0);
signal c : in std_logic_vector(31 downto 0);
signal d : in std_logic_vector(31 downto 0);
signal e : out std_logic_vector(31 downto 0);
signal f : out std_logic_vector(31 downto 0)
is
variable x : std_logic_vector(31 downto 0);
variable y : std_logic_vector(31 downto 0);
begin
x := (others => '0');
y := (others => '0');
for i in 0 to 31 loop
x(i) := (a(i) xor b(i)) and (c(i) xor d(i));
y(i) := (a(i) xor b(i)) or ((d(i) xor c(i)) xor b(i));
end loop;
e <= x(31 downto 0);
f <= y(31 downto 0);
end;
procedure main
signal r : out std_logic_vector(31 downto 0)
is
variable res : std_logic_vector(31 downto 0);
variable t0, t1 : std_logic_vector(31 downto 0);
constant c : std_logic_vector(31 downto 0) := X"fedcba90";
constant d : std_logic_vector(31 downto 0) := X"7654321f";
begin
t0 := (others => '0');
t1 := (others => '0');
if ( (c(i) = '0') && (d(i) = '1') ) then
subproc( t0, t1,
a, b, t0, t1 );
end if;
end loop;
r <= t0;
end;
