Register Log in
VHDL SINE LUT using type "real"
shaiko
Advanced Member level 5
Hello,
I'm trying to design a generic synthesizable SINE LUT in VHDL.
I'm using the "real" type to compute the LUT's values during compile time.
This is my code:
library ieee ;
	use ieee.std_logic_1164.all ;
	use ieee.numeric_std.all ;
	use ieee.math_real.all ;
entity sine_lut is
generic
    WIDTH_FRACTION_ANGLE    : natural := 4  ; -- 4 gives us a resolution of 1/16
    WIDTH_FRACTION_RESULT   : natural := 10
port
	IN_CLOCK    :   in  std_logic                                                   ;
	IN_ANGLE    :   in  std_logic_vector ( 7 + WIDTH_FRACTION_ANGLE - 1 downto 0 )  ;   -- 90 is 1011010 ( 7 bits ). A sign bit isn't needed ( the user shall exploit the sine symmetry ).
	OUT_RESULT  :   out std_logic_vector ( WIDTH_FRACTION_RESULT downto 0 )             -- One integer bit + WIDTH_FRACTION_RESULT
end entity sine_lut ;
architecture rtl_sine_lut of sine_lut is
type type_lut_sine_real     is array ( 0 to 2 ** ( IN_ANGLE ' length ) - 1 ) of real ;
type type_lut_sine_slv      is array ( 0 to 2 ** ( IN_ANGLE ' length ) - 1 ) of std_logic_vector ( OUT_RESULT ' range ) ;
[COLOR="#FF0000"]signal lut_sine_real    : type_lut_sine_real ;
signal lut_sine_slv     : type_lut_sine_slv ;[/COLOR]
begin
    generate_sine_lut : for index in 0 to 2 ** ( IN_ANGLE ' length ) - 1
    generate
        lut_sine_real ( index ) <= sin ( real ( index ) * ( MATH_PI / 180.0 ) / ( real ( 2 ** WIDTH_FRACTION_ANGLE ) ) ) ;  -- Multiplying by ( MATH_PI / 180.0 ) converts from degrees to radians.
        lut_sine_slv ( index )  <= std_logic_vector ( to_unsigned ( integer ( lut_sine_real ( index ) * ( real ( 2 ** WIDTH_FRACTION_RESULT ) ) ) , OUT_RESULT ' length ) ) ;
    end generate ;
    reading_from_memory : process ( IN_CLOCK ) is
    begin
        if rising_edge ( IN_CLOCK ) then
            OUT_RESULT <= lut_sine_slv ( to_integer ( unsigned ( IN_ANGLE ) ) ) ;
        end if ;
    end process reading_from_memory ;
end architecture rtl_sine_lut ;
Unfortunately,
Quartus can't synthesize type "real" for arguments that are defined as signals. The following error is shown:
Error (10414): VHDL Unsupported Feature error at sine_lut.vhd(29): cannot synthesize non-constant real objects or values
But if I define the arrays as constants I can't use the neat "for loop" method to instantiate their values.
How can I work around this problem ?
TrickyDicky
Yes you can - define it all in an initialisation function:
Code VHDL - [expand]
8
9
10
11
12
13
constant sin_rom : type_lut
function define_rom return type_lut_sine_slv is
  variable ret_rl : type_lut_sine_real;
  variable ret : type_lut_sine_slv;
begin
  for index in ret'range loop
    ret_rl( index ) := sin ( real ( index ) * ( MATH_PI / 180.0 ) / ( real ( 2 ** WIDTH_FRACTION_ANGLE ) ) ) ;  -- Multiplying by ( MATH_PI / 180.0 ) converts from degrees to radians.
    ret ( index )  := std_logic_vector ( to_unsigned ( integer ( lut_sine_real ( index ) * ( real ( 2 ** WIDTH_FRACTION_RESULT ) ) ) , OUT_RESULT ' length ) ) ;
  end loop;
end function;
constant rom : type_lut_sine_slv := define_rom;
Please put cheque in the post!
Reactions: shaiko
    shaiko
Toggle Sidebar
