VHDL Shift Register/running array
dareon
Newbie level 5
I am trying to program a shift register or running array(32 positions) that I can add one integer to (indexing all the rest of the points down and dropping off the last one), do some math, and then add another point.
Here is a simplified version of the code.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity NANOPOSITIONER is
Port (
DAC out ports and clock in ports and such... all verified working)
end NANOPOSITIONER;
architecture Behavioral of NANOPOSITIONER is
type int_array is array(0 to 31) of integer;
signal RUNNING_ARRAY1 : int_array;
other signals and processes for ADC/DAC control as well as luts tables.
RUNNING_ARRAY: process (SINE_INT )
begin
for i in 0 to 30 loop
RUNNING_ARRAY1(i +1) <= RUNNING_ARRAY1(i);
end loop;
RUNNING_ARRAY1(0) <= (SINE_INT) ;
end process;
--OUT3 is converted to a std_logic_vector and output via a DAC
-- at the same time I am outputting SINE_INT in the same manner
OUT3 <= DFT_ARRAY1(30);
end Behavioral;
SINE_INT comes from a LUT with 32 points .
Basically I have two sine wave outputs from OUT3 and SINE_INT going to seperate DACs. I would expect if I change the index of DFT_ARRAY1(?) being stored to OUT3 to some other value I should see a phase shift between these waves. It however always stays the same as if all the points in my array actually have the same data.
At this point I am not worried about the math I just want to get the array indexing properly.
Any help is appreciated.
Thank You
You get what you told the VHDL compiler:
process (SINE_INT )
begin
end loop;
end process;
The code is immedediately copying sine_int to all array locations, in other words it declares the array as an alias of sine_int without actually generating registers.
More exactly, it does in synthesis, behaving different in simulation. This happens because you apparently misunderstood the nature of the sensitivity list in a combinational process. Unlike a clocked process, it actually waits for nothing. To generate a delay chain, you have to use a clocked process instead.
process (clk)
begin
if rising_edge(clk) then
  end loop;
end if;
end process;
Reactions: dareon
    dareon
Just wondering, wont the following code copy the LSB bit into the MSB 30 bits?
end loop;
bit 0 first copied to bit 1 first.
then bit 1(which is same as bit 0 now) is copied to bit 2 and so on?
Will the following modification help?
RUNNING_ARRAY1(31 - i) <= RUNNING_ARRAY1(30 - i);
end loop;
It doesn't change anything. Please consider the VHDL rules for update of signals. All registers are updated after a delta cycle.
Would be different for a VHDL variable assignment respectively non-blocking assignment in Verilog.
FvM
Thanks for the help that got it working. I was under the mistaken impression that the process would only run once 1 thing in its sensitivity list changed.
