tzushky
Member level 3
- Joined
- May 21, 2007
- Messages
- 63
- Helped
- 10
- Reputation
- 20
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- Sophia-Antipolis,France
- Activity points
- 1,819
vhdl read
Hello again,
I have been looking throuhg Ashenden's Deisgner Guide to VHDL for file reading in VHDL. I thought it is the best way to drive test becnh signals: have a stimuli file read in the test bench entity and give values to the different needed signals at every clock event.
My problem => my file would contain values for 5 (or more ) signals and they are also of different kinds (enables : std_logic, 8b adresses or data ...)
I arranged them in this waysay for a ram test)
en we addr data q
0 0 00000001 10000001 00000000
1 1 00000010 10000010 00000000
etc... (data is like adress but with MSB=1)
I tried making a file type of a max 8 length vector (the book I mentioned advises that in case different length signal values are found in te file, the read function will have a 3 parameter prototype, read(file, target_vector, length_found). The target_vector is declared as a veriable of max size and normally if a found value is smaller than that length, the vector is filled form left to right. But I tried this on my file and it doesn't work, gives me range error...
I'll show you the code:
NCSim error:
ncvhdl: 08.10-p002: (c) Copyright 1995-2008 Cadence Design Systems, Inc.
read(stimulus, str_en,read_len);
ncvhdl_p: *E,ALTYMM (../hdl/tb_ram.vhd,85|35): subprogram call or operator argument type mismatch 87[4.3.3.2] 93[4.3.2.2].
Where am I going wrong? I have searched for code examples on the web... I suspect it's the separator of my value sin the text file or... I don't know...
Any ideas?
Thanks in advance,
T
Hello again,
en we addr data q
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity tb_ram is
end entity tb_ram;
architecture tb_arch of tb_ram is
constant addr_len : integer := 8;
constant data_len : integer := 8;
component sram is
generic(
g_addr_length : integer ;
g_data_length : integer
port
clk : in std_logic;
en : in std_logic;
we : in std_logic;
a : in std_logic_vector(g_addr_length-1 downto 0);
d : in std_logic_vector(g_data_length-1 downto 0);
q : out std_logic_vector(g_data_length-1 downto 0)
end component;
type text is file of std_logic_vector;
file stimulus: text open read_mode is "stimuli.txt";
signal int_clk: std_logic;
signal int_we : std_logic;
signal int_en : std_logic;
signal int_a:std_logic_vector(addr_len-1 downto 0);
signal int_d:std_logic_vector(data_len-1 downto 0);
signal int_q:std_logic_vector(data_len-1 downto 0);
signal int_verif: std_logic;
begin
--instance sram
tb_i_sram: sram
generic map(
g_addr_length =>addr_len,
g_data_length =>data_len
port map(
clk => int_clk,
en => int_en,
we => int_we,
a => int_a,
d => int_d,
q => int_q
p_clk: process
begin
int_clk<='0';
wait for 8333 ps;
int_clk<='1';
wait for 8333 ps;
end process;
recv_data_process:process
variable read_len:natural;
variable str_en : std_logic_vector(addr_len downto 0);
variable str_we : std_logic_vector(addr_len-1 downto 0);
variable str_a : std_logic_vector(addr_len-1 downto 0);--string(g_addr_length);
variable str_d : std_logic_vector(data_len-1 downto 0);--string(g_data_length);
variable str_q : std_logic_vector(data_len-1 downto 0);--string(g_data_length);
begin
while not endfile(stimulus) loop
int_verif<='0';
--first on line: en signal
int_en <= str_en(1);
--we signal
read(stimulus, str_we,read_len);
int_we <= str_we(0);
--a address signal
read(stimulus,str_a ,read_len);
int_a <= str_a;
--d address signal
read(stimulus,str_d ,read_len);
int_d <= str_d;
--q address signal check
read(stimulus, str_q,read_len);
if (int_q = str_q) then
int_verif <='1';
end if;
wait until int_clk = '1';
end loop;
wait;
end process;
end tb_arch;
NCSim error:
Any ideas?
Thanks in advance,
T
