VHDL, Quartus II - Error: formal port or parameter must have actual or default value
newbie99
Newbie level 3
I am getting the following two errors: Error (10346): VHDL error at comparator_TestBench.vhd(17): formal port or parameter "beginGame" must have actual or default value
Error (10784): HDL error at comparator.vhd(8): see declaration for object "beginGame"
and both are related to assigning a default value for beginGame in my comparator.vhd file:
entity comparator is
port(
        beginGame               : in std_logic; -- Error in this line
        hexDraft, hexReal   : in std_logic_vector(6 downto 0);
        hexPosition             : in std_logic_vector(1 downto 0);
        newHex                  : out std_logic_vector(6 downto 0);
        newHexPosition          : out std_logic_vector(1 downto 0));
end comparator;
architecture Behav of comparator is
    signal s_hexPosition : std_logic_vector(1 downto 0);
begin
comp : process(hexDraft, hexReal, hexPosition, s_hexPosition)
begin
    if(beginGame = '1') then
        if((hexDraft(0) = '0' and hexReal(0) = '0') or (hexDraft(1) = '0' and hexReal(1) = '0') or (hexDraft(2) = '0' and hexReal(2) = '0')
        or (hexDraft(3) = '0' and hexReal(3) = '0') or (hexDraft(4) = '0' and hexReal(4) = '0') or (hexDraft(5) = '0' and hexReal(5) = '0')
        or (hexDraft(6) = '0' and hexReal(6) = '0')) then
            if(hexPosition = "00") then
                s_hexPosition <= "10";
            elsif(hexPosition = "01") then
                s_hexPosition <= "11";
            elsif(hexPosition = "10") then
                s_hexPosition <= "00";
            else
                s_hexPosition <= "01";
            end if;
        else
            s_hexPosition <= hexPosition;
        end if;
    end if;
    newHexPosition <= s_hexPosition;
    newHex <= hexDraft;
end process;
end Behav;
and this's the part giving me an error in my comparator_TestBench.vhd file, which depends on my comparator.vhd
entity comparator_TestBench is
end comparator_TestBench;
architecture Stimulus of comparator_TestBench is
    -- signal   s_notClock50Mhz         : std_logic;
    signal  s_hexDraft, s_hexReal   : std_logic_vector(6 downto 0);
    signal  s_newHex                    : std_logic_vector(6 downto 0);
    signal  s_newHexPosition            : std_logic_vector(1 downto 0);
begin
        uut : entity work.comparator(Behav) -- Error in this line
            port map(
--              notClock50Mhz   => s_notClock50Mhz,
                hexDraft            => s_hexDraft,
                hexReal         =>  s_hexReal,
                hexPosition     => s_hexPosition,
                newHex          => s_newHex,
                newHexPosition  => s_newHexPosition
I'm using altera DE2-115 board and Quartus II software
Any advice/ suggestions would be much appreciated.
Isn't the error message pretty clear? You are missing to assign an actual value to parameter "beginGame" which is then undefined in the instantiated component.
Solutions are:
assign a value in the port map, e.g.
beginGame => '1',
or define a default value in the port declaration, which will be used if no actual value is given
beginGame     : in std_logic := '1';
Solutions are:
beginGame => '1',
Thanks FvM, this solved the error. Yes, you're right it's pretty obvious.
