VHDL(procedure)----verilog(task)
xihushui
Member level 2
vhdl procedure
this is a procedure in VHDL,but now i want to change it to a task in verilog.how to do it ? stopBitLength is real,is not a in or out(in fact,it is in),how to do in task of verilog?
procedure sout_chk (
numDataBits : integer range 5 to 8;
Txdata : in std_logic_vector(7 downto 0);
ParityBit : in std_logic;
stopBitLength : real;
parityBitExist : boolean;
constant cycleTime : in time;
signal SOUT : in std_logic) is
variable i : integer;
begin
endtask
task vhdl
I guess you are wondering how to pass stopBitLength into verilog tasks? You can do this is two ways
1. If this is the case you can use the "parameter" option in verilog. You can define stopBitLength as parameter and directly use stopBitLength inside the tasks without even declaring them in the task declaration list.
2. You can also use intergers & real data type objects as inputs to the task so in your case you can defineas
task sout_chk;
input integer numDataBits;
input [7:0] Txdata;
input ParityBit;
input real stopBitLength
input boolean parityBitExist;
input SOUT;
begin
end
endtask
