vhdl port instantiation types
Bustigo
Member level 2
what is the difference between instantiation with writing a component, with declaring the architecture , with just wriring entity work.entity_name
can you please write the correct declaration of e
K-J
Advanced Member level 2
- Writing a component declaration that then gets instantiated takes more work and is also subject to errors that can be difficult to figure out because the error messages aren't always that helpful
- Instantiating an entity directly with 'The_Widge : entiry work.Widget ...' is less work and avoids the problems that will come up with a component declaration.
- Using a component declaration is required when you don't have the code for the entity/architecture because it has been provided as a black box by someone else
Kevin Jennings
