Register Log in
VHDL - Launch ModelSim shell file
wolfy_
Newbie level 2
I am trying to launch ModelSim from a file because I need to launch three separate ModelSim at the same time.
I created the file pre_compile.sh:
vlib work
vcom Digital1101.vhd Digital1111.vhd NOT_rsvd.vhd
vsim -foreign "simlinkserver solaris32/liblfmhdls_gcc412.so;-socket 5678"-novopt Digital1111 &
vsim -foreign "simlinkserver solaris32/liblfmhdls_gcc412.so;-socket 5679"-novopt Digital1101 &
vsim -foreign "simlinkserver solaris32/liblfmhdls_gcc412.so;-socket 5680"-novopt NOT_rsvd &
but when I call the file. / pre_compile.sh it compiles the files .vhd but ModelSim will not start.
I think the problem is with the symbol &
Is there any solution that can help me?
Thanks
shravan87
Junior Member level 3
USA
Modelsim has a particular syntax that lets you run scripts. I'm not sure about this, you can check this in the manual.
Try: vsim <top_level> -do sim.do
This loads the top level, and modelsim reads the sim.do file. This file should obviously only have modelsim instructions and no shell instructions.
wolfy_
Newbie level 2
I think I have found the solution
vlib work
vsim -foreign "simlinkserver solaris32/liblfmhdls_gcc412.so;-socket 5678"-novopt Digital1111 Digital1101 NOT_rsvd
So when the ModelSim launch it run's with all blocks in the same socket
Toggle Sidebar
