VHDL integer to integer multiplication
shaiko
Advanced Member level 5
Hello,
This is the definition of the "numeric_std" multiplication function ( '*' )
  -- Id: A.15
  function "*" (L, R: UNSIGNED) return UNSIGNED;
  -- Result subtype: UNSIGNED((L'LENGTH+R'LENGTH-1) downto 0).
  -- Result: Performs the multiplication operation on two UNSIGNED vectors
  --         that may possibly be of different lengths.
  -- Id: A.16
  function "*" (L, R: SIGNED) return SIGNED;
  -- Result subtype: SIGNED((L'LENGTH+R'LENGTH-1) downto 0)
  -- Result: Multiplies two SIGNED vectors that may possibly be of
  --         different lengths.
  -- Id: A.17
  function "*" (L: UNSIGNED; R: NATURAL) return UNSIGNED;
  -- Result subtype: UNSIGNED((L'LENGTH+L'LENGTH-1) downto 0).
  -- Result: Multiplies an UNSIGNED vector, L, with a non-negative
  --         INTEGER, R. R is converted to an UNSIGNED vector of
  --         SIZE L'LENGTH before multiplication.
  -- Id: A.18
  function "*" (L: NATURAL; R: UNSIGNED) return UNSIGNED;
  -- Result subtype: UNSIGNED((R'LENGTH+R'LENGTH-1) downto 0).
  -- Result: Multiplies an UNSIGNED vector, R, with a non-negative
  --         INTEGER, L. L is converted to an UNSIGNED vector of
  --         SIZE R'LENGTH before multiplication.
  -- Id: A.19
  function "*" (L: SIGNED; R: INTEGER) return SIGNED;
  -- Result subtype: SIGNED((L'LENGTH+L'LENGTH-1) downto 0)
  -- Result: Multiplies a SIGNED vector, L, with an INTEGER, R. R is
  --         converted to a SIGNED vector of SIZE L'LENGTH before
  --         multiplication.
  -- Id: A.20
  function "*" (L: INTEGER; R: SIGNED) return SIGNED;
  -- Result subtype: SIGNED((R'LENGTH+R'LENGTH-1) downto 0)
  -- Result: Multiplies a SIGNED vector, R, with an INTEGER, L. L is
  --         converted to a SIGNED vector of SIZE R'LENGTH before
  --         multiplication.
It seems that multiplication of (L: INTEGER; R: INTEGER) isn't defined.
However,
The following code does compile in Modelsim:
signal x,y,z : integer ;
z <= x * y ;
2 Questions:
1. If it's undefined in the library - why does it work ?
2. Will the result be considered as signed or unsigned ?
std_match
Sweden
integer is not a datatype from numeric_std. It is a built-in datatype.
No library/package is needed for integer*integer.
The result is an integer.
Reactions: shaiko
    shaiko
shaiko
Thanks,
Is it possible to force an integer to be less then 32 bits long ?
std_match
Sweden
Thanks,
An integer has no bits, it is only a value. You can use "range" to restrict the possible values.
I think it is required that the internal representation in the simulator has at least 32 bits.
signed and unsigned have bits.
It is important to know that signed and unsigned from numeric_std wraps around when the max/min values are exceeded.
If an integer exceeds max/min there is an error in the simulation.
Reactions: shaiko
    shaiko
