library ieee;
--library work;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity FIFO8x9 is
port(
clk, rst: in std_logic;
RdPtrClr, WrPtrClr: in std_logic;
RdInc, WrInc: in std_logic;
DataIn: in std_logic_vector(8 downto 0);
DataOut: out std_logic_vector(8 downto 0);
rden, wren: in std_logic
end entity FIFO8x9;
architecture RTL of FIFO8x9 is
type fifo_array is array(7 downto 0) of std_logic_vector(8 downto 0); -- makes use of VHDL’s enumerated type
signal fifo: fifo_array;
signal wrptr, rdptr: unsigned(2 downto 0);
signal en: std_logic_vector(7 downto 0);
signal dmuxout: std_logic_vector(8 downto 0);
begin
-- fifo register array:
reg_array: process (rst, clk)
begin
if rst = '1' then
for i in 7 downto 0 loop
fifo(i) <= (others => '0');
end loop;
elsif (clk'event and clk = '1') then
if wren = '1' then
if en(i) = '1' then
fifo(i) <= DataIn;
else
fifo(i) <= fifo(i);
end if;
end loop;
end if;
end if;
end process reg_array;
-- read pointer
read_count: process (rst, clk)
begin
if rst = '1' then
rdptr <= (others => '0');
elsif (clk'event and clk='1') then
if rdptrclr = '1' then
elsif rdinc = '1' then
rdptr <= rdptr + 1;
end if;
end if;
end process read_count;
-- write pointer
write_count: process (rst, clk)
begin
if rst = '1' then
wrptr <= (others => '0');
if wrptrclr = '1' then
elsif wrinc = '1' then
wrptr <= wrptr + 1;
end if;
end if;
end process write_count;
-- 8:1 output data mux
with std_logic_vector(rdptr) select
dmuxout <= fifo(0) when "000",
fifo(1) when "001",
fifo(2) when "010",
fifo(3) when "011",
fifo(4) when "100",
fifo(5) when "101",
fifo(6) when "110",
fifo(7) when others;
-- FIFO register selector decoder
with std_logic_vector(wrptr) select
en <= "00000001" when "000",
"00000010" when "001",
"00000100" when "010",
"00001000" when "011",
"00010000" when "100",
"00100000" when "101",
"01000000" when "110",
"10000000" when others;
-- three-state control of outputs
three_state: process (rden, dmuxout)
begin
DataOut <= dmuxout when rden = '1' else "ZZZZZZZZZ";
end process three_state;
end RTL;
