Register Log in
VHDL FF based memory array
shaiko
Advanced Member level 5
Hello,
When I have a FF based memory array and I want to bring it's ports to the entity's output - I concatanate all the memory cells to a single long vector of length: memory_depth * memory_width
But is it possible to define the entity I/Os themselves as a 2D array ?
TrickyDicky
Yes. You'll have to declare the type in a package though.
shaiko
Please elaborate.
Can you show an example please...
TrickyDicky
package types_package is
  type 2d_array_t is array(natural range <>, natural range <>) of integer;
end package;
use work.types_package.all;
entity some_ent is
  generic(
    MEMORY_DEPTH : natural;
    MEMORY_WIDTH : natural
  port (
    regs : out 2d_array_t(0 to MEMORY_DEPTH-1, 0 to MEMORY_WIDTH-1)
end entity;
Reactions: shaiko
    shaiko
shaiko
THANKS TrickyDicky !
BTW ;
Does Verilog has this type as a standart ?
TrickyDicky
I dont know a lot about verilog, but afaik standard verilog limits arrays to 2d (its limitless in VHDL). SystemVerilog removes this restriction.
shaiko
But only 2D's are synthesizable...yes, I know that.
What I meant is:
Per your explanation I see that an array IO isn't a standart type in VHDL - and requires a type def to work...I asked if array IOs in Verilog are a standart feature of the language?
Toggle Sidebar
