billywu223
Newbie level 1
Hi, guys!
I have a simple code to load a serial input.
And the testbench is
Could some one tell me why I get fatal error in the process when the clock reach the falling edge in Modelsim.
Please..........................:bang:
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 ------------------------------------------ library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; entity test is Port ( Dclk : in STD_LOGIC; InputL : in STD_LOGIC; Frame : in STD_LOGIC; rj_L : out STD_LOGIC_VECTOR (15 downto 0) ); end test; architecture Behavioral of test is signal bit_count : std_logic_vector(4 downto 0) := "10000"; signal input_rdy_flag : std_logic := '0'; signal data_L : std_logic_vector(15 downto 0); begin process (Dclk) begin if ((Dclk'event) and (Dclk = '0')) then if (Frame = '1') then bit_count <= "01111"; input_rdy_flag <= '0'; data_L (conv_integer(bit_count)) <= InputL; else bit_count <= bit_count - "00001"; data_L (conv_integer(bit_count)) <= InputL; if (bit_count = "00000") then input_rdy_flag <= '1'; end if; end if; end if; if (input_rdy_flag = '1') then rj_L <= data_L; end if; end process; end Behavioral; -----------------------------------------------------------------------------------
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 ----------------------------------------------------------------------------------- LIBRARY ieee; USE ieee.std_logic_1164.ALL; ENTITY test_tb IS END test_tb; ARCHITECTURE behavior OF test_tb IS COMPONENT test PORT( Dclk : IN std_logic; InputL : IN std_logic; Frame : IN std_logic; rj_L : OUT std_logic_vector(15 downto 0) ); END COMPONENT; signal Dclk : std_logic := '0'; signal InputL : std_logic := '0'; signal Frame : std_logic := '1'; signal rj_L : std_logic_vector(15 downto 0); constant Dclk_period : time := 10 ns; constant rj: std_logic_vector(15 downto 0) := x"0020"; BEGIN -- Instantiate the Unit Under Test (UUT) uut: test PORT MAP ( Dclk => Dclk, InputL => InputL, Frame => Frame, rj_L => rj_L ); -- Clock process definitions Dclk_process :process begin Dclk <= '0'; wait for Dclk_period/2; Dclk <= '1'; wait for Dclk_period/2; end process; -- Stimulus process stim_proc: process begin -- hold reset state for 100 ns. wait for 100 ns; InputL <= rj (15); Frame <= '1'; wait for Dclk_period; InputL <= rj (14); Frame <= '0'; wait for Dclk_period; InputL <= rj (13); Frame <= '0'; wait for Dclk_period; InputL <= rj (12); Frame <= '0'; wait for Dclk_period; InputL <= rj (11); Frame <= '0'; wait for Dclk_period; InputL <= rj (10); Frame <= '0'; wait for Dclk_period; InputL <= rj (9); Frame <= '0'; wait for Dclk_period; InputL <= rj (8); Frame <= '0'; wait for Dclk_period; InputL <= rj (7); Frame <= '0'; wait for Dclk_period; InputL <= rj (6); Frame <= '0'; wait for Dclk_period; InputL <= rj (5); Frame <= '0'; wait for Dclk_period; InputL <= rj (4); Frame <= '0'; wait for Dclk_period; InputL <= rj (3); Frame <= '0'; wait for Dclk_period; InputL <= rj (2); Frame <= '0'; wait for Dclk_period; InputL <= rj (1); Frame <= '0'; wait for Dclk_period; InputL <= rj (0); Frame <= '0'; end process; END; --------------------------------------------------------------
