library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.numeric_std.ALL;
entity Freq_Counter is
Port ( Clk : in STD_LOGIC;
Data : in STD_LOGIC;
seg : out STD_LOGIC_VECTOR (6 downto 0);
an: out STD_LOGIC_VECTOR (3 downto 0));
end Freq_Counter;
architecture Behavioral of Freq_Counter is
signal SD1 : std_logic_vector(3 downto 0):="0000" ;
signal SD2 : std_logic_vector(3 downto 0):="0000" ;
signal SD3 : std_logic_vector(3 downto 0):="0000" ;
signal Freq:integer range 0 to 300 :=0;
signal N_Ticks: integer range 0 to 50000 :=0;
component Segment
port(
Clk : in STD_LOGIC;
Value1 : in STD_LOGIC_VECTOR (3 downto 0);
Value2 : in STD_LOGIC_VECTOR (3 downto 0);
Value3 : in STD_LOGIC_VECTOR (3 downto 0);
end component;
begin
Segments : Segment
port map(
Clk => Clk,
Value1 => SD1,
Value2 => SD2,
Value3 => SD3,
seg => seg,
an => an);
process(Data,Clk)
Variable Ready : integer range 0 to 3 :=0;
Variable N_Tick: integer range 0 to 50000 :=0;
begin
--------------------------BEGIN----------------------------
if Clk'event and Clk ='1' then
case Ready is
when 0 =>
if Data ='1' then
Ready :=1;
end if;
when 1 =>
N_tick := N_tick +1;
if Data ='0' then
Ready:=2;
end if;
if N_tick > 100000 then
N_tick:=0;
Ready:=3;
end if;
when 2 =>
if Data ='1' then
N_ticks <= N_tick;
Ready:=3;
end if;
N_tick:=0;
Ready:=3;
end if;
when 3 =>
if Data ='0' then
N_tick:=0;
Ready:=0;
end if;
end case;
end if;
END PROCESS;
process(CLK)
constant Speed : integer:=100000;
Variable duom1 : integer range 0 to 100000 :=0;
begin
duom1:=duom1+1;
if duom1>10000 then
Freq <= Speed/N_ticks;
duom1:=0;
end if;
end if;
END PROCESS;
process(CLK)
Variable D1 : integer range 0 to 9 :=0;
Variable D2 : integer range 0 to 9 :=0;
Variable D3 : integer range 0 to 9 :=0;
Variable duom2 : integer range 0 to 100000 :=0;
begin
duom2:=duom2+1;
if duom2 > 10000 then
D3 := freq/100;
D2 :=(freq/10)mod 10 ;
D1 := freq mod 10;
if D1 = 1 then
SD1 <= "0001";
elsif D1 = 2 then
SD1 <= "0010";
elsif D1 = 3 then
SD1 <= "0011";
elsif D1 = 4 then
SD1 <= "0100";
elsif D1 = 5 then
SD1 <= "0101";
elsif D1 = 6 then
SD1 <= "0110";
elsif D1 = 7 then
SD1 <= "0111";
elsif D1 = 8 then
SD1 <= "1000";
elsif D1 = 9 then
SD1 <= "1001";
else
SD1 <= "0000";
end if;
if D2 = 1 then
SD2 <= "0001";
elsif D2 = 2 then
SD2 <= "0010";
elsif D2 = 3 then
SD2 <= "0011";
elsif D2 = 4 then
SD2 <= "0100";
elsif D2 = 5 then
SD2 <= "0101";
elsif D2 = 6 then
SD2 <= "0110";
elsif D2 = 7 then
SD2 <= "0111";
elsif D2 = 8 then
SD2 <= "1000";
elsif D2 = 9 then
SD2 <= "1001";
else
SD2 <= "0000";
end if;
if D3 = 1 then
SD3 <= "0001";
elsif D3 = 2 then
SD3 <= "0010";
elsif D3 = 3 then
SD3 <= "0011";
elsif D3 = 4 then
SD3 <= "0100";
elsif D3 = 5 then
SD3 <= "0101";
elsif D3 = 6 then
SD3 <= "0110";
elsif D3 = 7 then
SD3 <= "0111";
elsif D3 = 8 then
SD3 <= "1000";
elsif D3 = 9 then
SD3 <= "1001";
else
SD3 <= "0000";
end if;
duom2:=0;
end if;
end if;
end process;
end Behavioral;
