VHDL entity 2D array question
alexz
Full Member level 5
UK
vhdl entity array
I have defined a new type, which is a 2d array. An array of 10 latches 15 bits.
subtype	latchType	 is std_logic_vector(15 downto 0) ;
type 	latchesType  is array (9 downto 0) of latchType ;
signal	latches	:	latchesType := (others=>(others=>'0'));
Now, I want to instantiate an entity and pass a signal of this type to the entity.
How can I do this?
label: entity WORK myEntity(myARC) port map ( latches .... );
entity myEntity is
port
(latchesSignal : in latchesType ; ??????????
aji_vlsi
Advanced Member level 2
Bangalore, India
vhdl entity port array
How can I do this?
entity myEntity is
port
Yes, I don't see an issue in doing that. A good coding style is to puth your type in a package say "latch_pkg" and use it.
package latch_pkg;
end package latch_pkg;
library work;
use work.latch_pkg.all;
entity myEntity is
port
Maybe I'm missing something?
HTH
Ajeetha, CVC
www.noveldv.com
alexz
Full Member level 5
UK
array of vhd
You are definitely not missing anything!
Its just me, who has never used packages.
Where is the best place to define them?
Why do you include a signal in the package and how do you use it?
Is this signal becoming a global or something?
I have tried to copy your lines and get an error on the "subtype" line:
Error (10500): VHDL syntax error at intLatches.vhd(2) near text "subtype"; expecting "is"
aji_vlsi
Bangalore, India
vhdl array entity
The syntax was not 100% accurate, use Emacs for Template fixing, it will take care of those "is/begin/end" etc. Or quick google should get you the exact syntax.
Good Luck
Ajeetha, CVC
www.noveldv.com
alexz
Full Member level 5
UK
vhdl array in entity
Right, it was actually the "is" was missing in the first line.
So, what about the signal defined in the package?
aji_vlsi
Bangalore, India
ncmirror array
Yes signal in package will become sort of global - wherever the packgae is used. See VHDL FAQ at www.vhdl.org/comp.lang.vhdl
BTW, AFAIK Signal in pkg is non synthesizable - if you care! What's the need for signals in package? For Testbench? Maybe you should use SignalSpy/NCMirror/HDL_XMR.
Ajeetha, CVC
www.noveldv.com
