NYFinest
Newbie level 3
- Joined
- Nov 29, 2013
- Messages
- 3
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 85
Hello,
I am currently working on designing a CPU using VHDL. I am currently working on the register file portion and running into difficulties.
The design is output the contents of the registers on the input. The values are read out on a positive clock edge, values are written on negative clock edge. There is also forwarding if write register and a read register is the same, in that case the new value is sent out first then written.
Now, in my test bench if i write values first then read them after it works as expected. In reality I want to read the values first, since I am going to preload the registers with random values. In the code you'll see reg(0) - reg(3) loaded with the value. In the test want to read register 0 but I get all outputs as "U". If I comment out my write process then I get the values I want. I cant figure out whats wrong with my code.
My questions are:
Is there a way to load the register array inside my module in the testbench?
Am I doing something wrong in my module and how can I fix it.
Thank you for your time.
Module
TestBench
My questions are:
Module
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity register_file is port( clk : in std_logic; write : in std_logic; regA : in std_logic_vector(3 downto 0); regB : in std_logic_vector(3 downto 0); regW : in std_logic_vector(3 downto 0); dataA : out std_logic_vector(63 downto 0); dataB : out std_logic_vector(63 downto 0); dataW : in std_logic_vector(63 downto 0) ); end register_file; architecture behavioral of register_file is type reg_array is array(15 downto 0) of std_logic_vector(63 downto 0); signal reg : reg_array; signal data_write : std_logic_vector(63 downto 0); begin reg(0) <= X"FFFFEEEEAAAABBBB"; reg(1) <= X"FFFFEEEEAAAABBBB"; reg(2) <= X"FFFFEEEEAAAABBBB"; read_prc: process(clk) begin if rising_edge(clk) then dataA <= reg(to_integer(unsigned(regA))); dataB <= reg(to_integer(unsigned(regB))); end if; end process read_prc; write_prc: process(clk, write) begin if (write = '1' AND falling_edge(clk)) then data_write <= dataW; reg (to_integer(unsigned(regW))) <= data_write; end if; end process write_prc; bypass_prc: process(clk) begin if (regA = regW) then if write = '1' then if rising_edge(clk) then dataA <= dataW; end if; end if; end if; if (regB = regW) then if write = '1' then if rising_edge(clk) then dataB <= dataW; end if; end if; end if; end process bypass_prc; end behavioral;
TestBench
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 LIBRARY ieee; USE ieee.std_logic_1164.ALL; USE ieee.std_logic_unsigned.all; -- entity declaration for your testbench.Dont declare any ports here ENTITY test_tb IS END test_tb; ARCHITECTURE behavior OF test_tb IS -- Component Declaration for the Unit Under Test (UUT) COMPONENT register_file --'test' is the name of the module needed to be tested. --just copy and paste the input and output ports of your module as such. PORT( clk : in std_logic; write : in std_logic; regA : in std_logic_vector(3 downto 0); regB : in std_logic_vector(3 downto 0); regW : in std_logic_vector(3 downto 0); dataA : out std_logic_vector(63 downto 0); dataB : out std_logic_vector(63 downto 0); dataW : in std_logic_vector(63 downto 0) ); END COMPONENT; --declare inputs and initialize them signal clk : std_logic := '0'; signal write : std_logic := '0'; signal regA : std_logic_vector(3 downto 0) := "0000"; signal regB : std_logic_vector(3 downto 0) := "0000"; signal regW : std_logic_vector(3 downto 0) := "0001"; signal dataW : std_logic_vector(63 downto 0) := X"0000000000000FFF"; --declare outputs and initialize them signal dataA : std_logic_vector(63 downto 0); signal dataB : std_logic_vector(63 downto 0); -- Clock period definitions constant clk_period : time := 50 ns; BEGIN -- Instantiate the Unit Under Test (UUT) uut: register_file PORT MAP ( clk => clk, write => write, regA => regA, regB => regB, regW => regW, dataA => dataA, dataB => dataB, dataW => dataW ); -- Clock process definitions( clock with 50% duty cycle is generated here. clk_process :process begin clk <= '0'; wait for clk_period/2; --for 0.5 ns signal is '0'. clk <= '1'; wait for clk_period/2; --for next 0.5 ns signal is '1'. end process; -- Stimulus process stim_proc: process begin wait for 10 ns; -- regW <= "0001"; -- dataW <= X"0000000000000FFF"; -- wait for 5 ns; -- write <= '1'; -- wait for 5 ns; -- write <= '0'; -- wait for 10 ns; -- regW <= "0010"; -- dataW <= X"FFF000000000000A"; -- wait for 5 ns; -- write <= '1'; -- wait for 5 ns; -- write <= '0'; -- wait for 10 ns; -- regA <= "0001"; -- regB <= "0010"; -- wait for 5 ns; -- regW <= "0010"; -- dataW <= X"000000000000EEEE"; -- wait for 5 ns; -- write <= '1'; -- wait for 5 ns; -- write <= '0'; -- wait for 10 ns; write <= '0'; regA <= "0000"; regB <= "0000"; regW <= "0011"; end process; END;
