VHDL, CPLD code:Will this implementation works
Bond_2007
Newbie level 5
Hello,
I would like to use the following case statement:
test_bits<bit1,bit0>
case 00:
Make IO output PIN 7 high.
case 01:
Make IO output PIN 8 high.
If case 00 has ran, the IO PIN 7 is high, will it stays high even when case 01 is running? Is this a latch operation?
I am new to CPLD, any help is appreciated.
-B
nand_gates
Advanced Member level 3
Yes ur right! This will create a latch for both PIN7 and PIN 8
because you have not specified what value to drive on these pins
under all possible conditions!
Bond_2007
Newbie level 5
any other inputs are greatly appreciated.
-B
vlsi_whiz
Full Member level 4
Penang
As stated above, the code will result in two latches. To avoid latches use the following code structure:
case 00:
Make IO output PIN 8 low.
case 01:
Make IO output PIN 7 low.
You can also use the IF statement to do the same.
