[SOLVED] VHDL Counter Clock issue
eengr
Member level 4
I am trying to do VHDL design to generate PWM outputs.
The period, On time & Off time for the waveforms would be programmed into the FPGA registers by a micro controller in real time (using its parallel port interface).
I have a counter implemented in VHDL that counts with the ticks of FPGA_CLK
I would like to update my registers from buffers to Output registers at the rising edge say at T1
I would then like to update my PWMs outputs (ON or OFF depending upon what they read from Output registers at the rising edge of next pulse say at T2
Both these T1 & T2 MUST NOT appear at the time when the Counter is changing its state to ensure that Counter value is stable before we do any other transitions.
See the attached figure below:
Ideally, I would like to to update the Output registers @ T1 (rising as mentioned above AND update PWMs at falling edge (if possible) soon after T1 ( But i am not sure if that's possible so I decided to use the rising edge of T2 instead)
My VHDL file is:
Code VHDL - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
284
285
286
287
288
289
290
291
292
293
294
295
296
297
298
299
300
301
302
303
304
305
306
307
308
309
310
311
312
313
314
315
316
317
318
319
320
321
322
323
324
325
326
327
328
329
330
331
332
333
334
335
336
337
338
339
340
341
342
343
344
345
346
347
348
349
350
351
352
353
354
355
356
357
358
359
360
361
362
363
364
365
366
367
368
369
370
371
372
373
374
375
376
377
378
379
380
381
382
383
384
385
386
387
388
389
390
391
392
393
394
395
396
397
398
399
400
401
402
403
404
405
406
407
408
409
410
411
412
413
414
415
416
417
418
419
420
421
422
423
424
425
426
427
428
429
430
431
432
433
434
435
436
437
438
439
440
441
442
443
444
445
446
447
448
449
450
451
452
453
454
455
456
457
458
459
460
461
462
463
464
465
466
467
468
469
470
471
472
473
474
475
476
477
478
479
480
481
482
483
484
485
486
487
488
489
490
491
492
493
494
495
496
497
498
499
500
501
502
503
504
505
506
507
508
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
-- use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity main_src is
    Port (
            ISA_ABUS_IN : in  STD_LOGIC_VECTOR (7 downto 0);
            ISA_DBUS_INOUT : inout  STD_LOGIC_VECTOR (7 downto 0);
            ISA_IOR : in  STD_LOGIC;
            ISA_IOW : in  STD_LOGIC;
        --  ISA_SMEMR: in STD_LOGIC;
        --  ISA_SMEMW: in STD_LOGIC;
        --  ISA_MEMW: in STD_LOGIC;
        --  ISA_MEMR: in STD_LOGIC;
        --  ISA_BALE: in STD_LOGIC;
        --  ISA_AEN: in STD_LOGIC;
        --  ISA_IO16 : out STD_LOGIC;
        --  ISA_DATA_EN : out STD_LOGIC; --  Enable line for Level Shifter IC on Data Bus
        --  ISA_DATA_DIR: out STD_LOGIC; -- Direction line for Level Shifter IC on Data Bus
        --  ISA_CLK: in STD_LOGIC;  -- ISA_OSC is clock signal coming from ISA BUS PC104 side
            FPGA_OSC : in  STD_LOGIC;
            PWM_OUT : out  STD_LOGIC_VECTOR (5 downto 0);
            COUNT_OUT : out  STD_LOGIC_VECTOR (15 downto 0);
            FPGA_DBUS_OUT1: out STD_LOGIC_VECTOR (7 downto 0);
            FPGA_DBUS_OUT2: out STD_LOGIC_VECTOR (7 downto 0);
            FPGA_DBUS_IN1: in   STD_LOGIC_VECTOR (7 downto 0));
end main_src;
architecture Behavioral of main_src is
    signal ISA_DBUS1 : STD_LOGIC_VECTOR (7 downto 0) := (others => '0');
    signal ISA_DBUS2 : STD_LOGIC_VECTOR (7 downto 0) := (others => '0');
    signal FPGA_DBUS11 : STD_LOGIC_VECTOR (7 downto 0) := (others => '0');
    signal FPGA_DBUS21 : STD_LOGIC_VECTOR (7 downto 0) := (others => '0');
    signal en1 : STD_LOGIC;
    signal pwm_sig : STD_LOGIC_VECTOR (5 downto 0) := (others => '0');
    -- Buffer registers
    signal bup1: STD_LOGIC_VECTOR (15 downto 0) := (others => '0');
    signal bdwn1: STD_LOGIC_VECTOR (15 downto 0) := (others => '0');
    signal bup2: STD_LOGIC_VECTOR (15 downto 0) := (others => '0');
    signal bdwn2: STD_LOGIC_VECTOR (15 downto 0) := (others => '0');
    signal bup3: STD_LOGIC_VECTOR (15 downto 0) := (others => '0');
    signal bdwn3: STD_LOGIC_VECTOR (15 downto 0) := (others => '0');
    signal bup4: STD_LOGIC_VECTOR (15 downto 0) := (others => '0');
    signal bdwn4: STD_LOGIC_VECTOR (15 downto 0) := (others => '0');
    signal bup5: STD_LOGIC_VECTOR (15 downto 0) := (others => '0');
    signal bdwn5: STD_LOGIC_VECTOR (15 downto 0) := (others => '0');
    signal bup6: STD_LOGIC_VECTOR (15 downto 0) := (others => '0');
    signal bdwn6: STD_LOGIC_VECTOR (15 downto 0) := (others => '0');
    signal btperiod: STD_LOGIC_VECTOR (15 downto 0) := (others => '0'); -- buffer Time period register
    -- Actual registers
    signal up1: STD_LOGIC_VECTOR (15 downto 0) := (others => '0');
    signal dwn1: STD_LOGIC_VECTOR (15 downto 0) := (others => '0');
    signal up2: STD_LOGIC_VECTOR (15 downto 0) := (others => '0');
    signal dwn2: STD_LOGIC_VECTOR (15 downto 0) := (others => '0');
    signal up3: STD_LOGIC_VECTOR (15 downto 0) := (others => '0');
    signal dwn3: STD_LOGIC_VECTOR (15 downto 0) := (others => '0');
    signal up4: STD_LOGIC_VECTOR (15 downto 0) := (others => '0');
    signal dwn4: STD_LOGIC_VECTOR (15 downto 0) := (others => '0');
    signal up5: STD_LOGIC_VECTOR (15 downto 0) := (others => '0');
    signal dwn5: STD_LOGIC_VECTOR (15 downto 0) := (others => '0');
    signal up6: STD_LOGIC_VECTOR (15 downto 0) := (others => '0');
    signal dwn6: STD_LOGIC_VECTOR (15 downto 0) := (others => '0');
    signal tperiod: STD_LOGIC_VECTOR (15 downto 0) := (others => '0'); -- Time period register
    signal periodlatch : STD_LOGIC_VECTOR (1 downto 0) := (others => '0');
    signal updatecounter : STD_LOGIC_VECTOR (1 downto 0) := (others => '0');
    -- sreg -- bits x-x-x-TE-ME-SC-LP-LC
    -- LC: Load Counter (UP/DOWNS) when '1' Buffer ready
    -- LP: Load Period when '1' Buffer ready
    -- SC : Start Counter - tcount when '1'
    -- ME : Master Enable - When '1' sends pwm signals to output else PWM outputs are 0FF
    -- TE: Timing Error - An invalid value loaded in the UP & DOWN Registers e.g., > tperiod
    signal sreg: STD_LOGIC_VECTOR (7 downto 0) := (others => '0'); -- status register
    signal tcount: STD_LOGIC_VECTOR (15 downto 0) := (others => '0'); -- Counter register
    -- Register Addresses
    constant ADDRESSUL1: STD_LOGIC_VECTOR (7 downto 0) := X"51"; -- Address for UP1 LOWER 8bits
    constant ADDRESSUH1: STD_LOGIC_VECTOR (7 downto 0) := X"52"; -- Address for UP1 HIGHER 8 bits
    constant ADDRESSDL1: STD_LOGIC_VECTOR (7 downto 0) := X"53"; -- Address for DWN1 LOWER 8bits
    constant ADDRESSDH1: STD_LOGIC_VECTOR (7 downto 0) := X"54"; -- Address for DWN1 HIGHER 8 bits
    constant ADDRESSUL2: STD_LOGIC_VECTOR (7 downto 0) := X"55"; -- Address for UP2 LOWER 8bits
    constant ADDRESSUH2: STD_LOGIC_VECTOR (7 downto 0) := X"56"; -- Address for UP2 HIGHER 8 bits
    constant ADDRESSDL2: STD_LOGIC_VECTOR (7 downto 0) := X"57"; -- Address for DWN2 LOWER 8bits
    constant ADDRESSDH2: STD_LOGIC_VECTOR (7 downto 0) := X"58"; -- Address for DWN2 HIGHER 8 bits
    constant ADDRESSUL3: STD_LOGIC_VECTOR (7 downto 0) := X"59"; -- Address for UP3 LOWER 8bits
    constant ADDRESSUH3: STD_LOGIC_VECTOR (7 downto 0) := X"5A"; -- Address for UP3 HIGHER 8 bits
    constant ADDRESSDL3: STD_LOGIC_VECTOR (7 downto 0) := X"5B"; -- Address for DWN3 LOWER 8bits
    constant ADDRESSDH3: STD_LOGIC_VECTOR (7 downto 0) := X"5C"; -- Address for DWN3 HIGHER 8 bits
    constant ADDRESSUL4: STD_LOGIC_VECTOR (7 downto 0) := X"5D"; -- Address for UP4 LOWER 8bits
    constant ADDRESSUH4: STD_LOGIC_VECTOR (7 downto 0) := X"5E"; -- Address for UP4 HIGHER 8 bits
    constant ADDRESSDL4: STD_LOGIC_VECTOR (7 downto 0) := X"5F"; -- Address for DWN4 LOWER 8bits
    constant ADDRESSDH4: STD_LOGIC_VECTOR (7 downto 0) := X"60"; -- Address for DWN4 HIGHER 8 bits
    constant ADDRESSUL5: STD_LOGIC_VECTOR (7 downto 0) := X"61"; -- Address for UP5 LOWER 8bits
    constant ADDRESSUH5: STD_LOGIC_VECTOR (7 downto 0) := X"62"; -- Address for UP5 HIGHER 8 bits
    constant ADDRESSDL5: STD_LOGIC_VECTOR (7 downto 0) := X"63"; -- Address for DWN5 LOWER 8bits
    constant ADDRESSDH5: STD_LOGIC_VECTOR (7 downto 0) := X"64"; -- Address for DWN5 HIGHER 8 bits
    constant ADDRESSUL6: STD_LOGIC_VECTOR (7 downto 0) := X"65"; -- Address for UP6 LOWER 8bits
    constant ADDRESSUH6: STD_LOGIC_VECTOR (7 downto 0) := X"66"; -- Address for UP6 HIGHER 8 bits
    constant ADDRESSDL6: STD_LOGIC_VECTOR (7 downto 0) := X"67"; -- Address for DWN7 LOWER 8bits
    constant ADDRESSDH6: STD_LOGIC_VECTOR (7 downto 0) := X"68"; -- Address for DWN7 HIGHER 8 bits
-- How are we going to ensure that both bytes have been loaded before updating
-- the PWM ON/OFF timings as it is 8 bit bus
    constant ADDRESSFQL: STD_LOGIC_VECTOR (7 downto 0) := X"69"; -- Address for PERIOD/FREQ LOWER 8 bits
    constant ADDRESSFQH: STD_LOGIC_VECTOR (7 downto 0) := X"6A"; -- Address for PERIOD/FREQ HIGHER 8 bits
    constant ADRSSTATS1: STD_LOGIC_VECTOR (7 downto 0) := X"11"; -- Address for STATUS REGISTER-1
begin
--  main_pwm0_unit: entity work.pwm (pwm_arch)
--          port map (FPGA_OSC => FPGA_OSC, PWM_OUT => PWM_OUT);
                ISA_DBUS1 <= ISA_DBUS_INOUT; -- Used as an input
                ISA_DBUS_INOUT <= ISA_DBUS2 when en1 = '1' else "ZZZZZZZZ"; -- Used as an output
                FPGA_DBUS_OUT1 <= FPGA_DBUS11; -- When value is written to output
                FPGA_DBUS_OUT2 <= FPGA_DBUS21; -- When value is written to output
                PWM_OUT(0) <= ( pwm_sig(0) AND sreg(3) ); -- PWM outputs would be enabled only if ME = '1' in sreg
                PWM_OUT(1) <= ( pwm_sig(1) AND sreg(3) );
                PWM_OUT(2) <= ( pwm_sig(2) AND sreg(3) );
                PWM_OUT(3) <= ( pwm_sig(3) AND sreg(3) );
                PWM_OUT(4) <= ( pwm_sig(4) AND sreg(3) );
                PWM_OUT(5) <= ( pwm_sig(5) AND sreg(3) );
                COUNT_OUT <= tcount ;
                process (FPGA_OSC)
                begin
                     if (rising_edge (FPGA_OSC)) then
                        if (ISA_IOW = '0' and ISA_IOR = '1') then -- Write is enabled
                            en1 <= '0';
                            if (ISA_ABUS_IN = ADDRESSUL1) then -- if address is ADDRESSUL1
                                bup1 (7 downto 0) <= ISA_DBUS1;
                            elsif (ISA_ABUS_IN = ADDRESSUH1) then -- if address is ADDRESSUH1
                                bup1 (15 downto 8) <= ISA_DBUS1;
                            elsif (ISA_ABUS_IN = ADDRESSDL1) then -- if address is ADDRESSDL1
                                bdwn1 (7 downto 0) <= ISA_DBUS1;
                            elsif (ISA_ABUS_IN = ADDRESSDH1) then -- if address is ADDRESSDH1
                                bdwn1 (15 downto 8) <= ISA_DBUS1;
                            elsif (ISA_ABUS_IN = ADDRESSUL2) then -- if address is ADDRESSUL2
                                bup2 (7 downto 0) <= ISA_DBUS1;
                            elsif (ISA_ABUS_IN = ADDRESSUH2) then -- if address is ADDRESSUH2
                                bup2 (15 downto 8) <= ISA_DBUS1;
                            elsif (ISA_ABUS_IN = ADDRESSDL2) then -- if address is ADDRESSDL2
                                bdwn2 (7 downto 0) <= ISA_DBUS1;
                            elsif (ISA_ABUS_IN = ADDRESSDH2) then -- if address is ADDRESSDH2
                                bdwn2 (15 downto 8) <= ISA_DBUS1;
                            elsif (ISA_ABUS_IN = ADDRESSUL3) then -- if address is ADDRESSUL3
                                bup3 (7 downto 0) <= ISA_DBUS1;
                            elsif (ISA_ABUS_IN = ADDRESSUH3) then -- if address is ADDRESSUH3
                                bup3 (15 downto 8) <= ISA_DBUS1;
                            elsif (ISA_ABUS_IN = ADDRESSDL3) then -- if address is ADDRESSDL3
                                bdwn3 (7 downto 0) <= ISA_DBUS1;
                            elsif (ISA_ABUS_IN = ADDRESSDH3) then -- if address is ADDRESSDH3
                                bdwn3 (15 downto 8) <= ISA_DBUS1;
                            elsif (ISA_ABUS_IN = ADDRESSUL4) then -- if address is ADDRESSUL4
                                bup4 (7 downto 0) <= ISA_DBUS1;
                            elsif (ISA_ABUS_IN = ADDRESSUH4) then -- if address is ADDRESSUH4
                                bup4 (15 downto 8) <= ISA_DBUS1;
                            elsif (ISA_ABUS_IN = ADDRESSDL4) then -- if address is ADDRESSDL4
                                bdwn4 (7 downto 0) <= ISA_DBUS1;
                            elsif (ISA_ABUS_IN = ADDRESSDH4) then -- if address is ADDRESSDH4
                                bdwn4 (15 downto 8) <= ISA_DBUS1;
                            elsif (ISA_ABUS_IN = ADDRESSUL5) then -- if address is ADDRESSUL5
                                bup5 (7 downto 0) <= ISA_DBUS1;
                            elsif (ISA_ABUS_IN = ADDRESSUH5) then -- if address is ADDRESSUH5
                                bup5 (15 downto 8) <= ISA_DBUS1;
                            elsif (ISA_ABUS_IN = ADDRESSDL5) then -- if address is ADDRESSDL5
                                bdwn5 (7 downto 0) <= ISA_DBUS1;
                            elsif (ISA_ABUS_IN = ADDRESSDH5) then -- if address is ADDRESSDH5
                                bdwn5 (15 downto 8) <= ISA_DBUS1;
                            elsif (ISA_ABUS_IN = ADDRESSUL6) then -- if address is ADDRESSUL6
                                bup6 (7 downto 0) <= ISA_DBUS1;
                            elsif (ISA_ABUS_IN = ADDRESSUH6) then -- if address is ADDRESSUH6
                                bup6 (15 downto 8) <= ISA_DBUS1;
                            elsif (ISA_ABUS_IN = ADDRESSDL6) then -- if address is ADDRESSDL6
                                bdwn6 (7 downto 0) <= ISA_DBUS1;
                            elsif (ISA_ABUS_IN = ADDRESSDH6) then -- if address is ADDRESSDH6
                                bdwn6 (15 downto 8) <= ISA_DBUS1;
                            elsif (ISA_ABUS_IN = ADDRESSFQL) then -- if address is ADDRESSFQL
                                btperiod (7 downto 0) <= ISA_DBUS1;
                            elsif (ISA_ABUS_IN = ADDRESSFQH) then -- if address is ADDRESSFQH
                                btperiod (15 downto 8) <= ISA_DBUS1;
                            elsif (ISA_ABUS_IN = ADRSSTATS1) then -- if address is ADRSSTATS1
                                sreg (3 downto 0) <= ISA_DBUS1 (3 downto 0);
                            end if;
                        end if;
                        if (ISA_IOW = '1' and ISA_IOR = '0') then -- Read is enabled
                            if (ISA_ABUS_IN = ADRSSTATS1) then -- if address is ADRSSTATS1 need to change this code
                                en1 <= '1';
                                ISA_DBUS2 <= sreg;
                            elsif (ISA_ABUS_IN = ADDRESSFQL) then -- if address is ADDRESSFQL need to change this code
                                en1 <= '1';
                                ISA_DBUS2 <= tperiod (7 downto 0);
                            elsif (ISA_ABUS_IN = ADDRESSFQH) then -- if address is ADDRESSFQH need to change this code
                                en1 <= '1';
                                ISA_DBUS2 <= tperiod (15 downto 8);
                            else
                                en1 <= '0';
                            end if;
                        end if;
                        if (ISA_IOW = '1' and ISA_IOR = '1') then -- ERROR when both Write & Read are enabled at same time
                            en1 <= '0';
                        end if;
                        if (ISA_IOW = '0' and ISA_IOR = '0') then -- ERROR when both Write & Read are enabled at same time
                            en1 <= '0';
                        end if;
                        if (sreg(0) = '1') then --LC = '1' and TE = '0'
                            up1 <= bup1;
                            up2 <= bup2;
                            up3 <= bup3;
                            up4 <= bup4;
                            up5 <= bup5;
                            up6 <= bup6;
                            dwn1 <= bdwn1;
                            dwn2 <= bdwn2;
                            dwn3 <= bdwn3;
                            dwn4 <= bdwn4;
                            dwn5 <= bdwn5;
                            dwn6 <= bdwn6;
                            sreg(0) <= '0'; -- Reset the LC bit for PIC
                        else
                        end if;
                        if (sreg(1) = '1' and periodlatch(0) = '0') then -- LP = '1' and periodlacth bit-0 = 0
                            tperiod <= btperiod;
                            sreg(1) <= '0'; -- Reset the LP bit for PIC
                            periodlatch(0) <= '1'; -- periodlacth bit-0 = 1 and never goes to 0 unless Power is switched OFF
                        else
                        end if;
                        --updatecounter <= updatecounter + 1; -- increment counter with each tick of 50MHz clock
                    --  if (updatecounter = "01") then
                    --  else
                        if (sreg(2) = '1') then -- SC = 1
                        end if;
                        if (tcount = (tperiod - 1) ) then -- tcount runs from 0 to tperiod-1
                                tcount <= (others =>'0'); -- reset counter when reaches tperiod value
                            else
                                tcount <= tcount + 1; -- increment counter with each tick of 50MHz clock.
                        end if;
                        end if;
                        if (updatecounter = "10") then
                        -- ***************************** PWM0 output start
                        if (up1 < dwn1) then
                            if (tcount >= up1 and tcount < dwn1) then
                                pwm_sig(0) <= '1';
                            else
                                pwm_sig(0) <= '0';
                            end if;
                        elsif (up1 > dwn1) then
                            if (tcount >= dwn1 and tcount < up1) then
                                pwm_sig(0) <= '0';
                            else
                                pwm_sig(0) <= '1';
                            end if;
                        else
                            pwm_sig(0) <= '0';
                        end if;
                        -- ***************************** PWM0 output finish
                        -- ***************************** PWM1 output start
                        if (up2 < dwn2) then
                            if (tcount >= up2 and tcount < dwn2) then
                                pwm_sig(1) <= '1';
                            else
                                pwm_sig(1) <= '0';
                            end if;
                        elsif (up2 > dwn2) then
                            if (tcount >= dwn2 and tcount < up2) then
                                pwm_sig(1) <= '0';
                            else
                                pwm_sig(1) <= '1';
                            end if;
                        else
                            pwm_sig(1) <= '0';
                        end if;
                        -- ***************************** PWM1 output finish
                        -- ***************************** PWM2 output start
                        if (up3 < dwn3) then
                            if (tcount >= up3 and tcount < dwn3) then
                                pwm_sig(2) <= '1';
                            else
                                pwm_sig(2) <= '0';
                            end if;
                        elsif (up3 > dwn3) then
                            if (tcount >= dwn3 and tcount < up3) then
                                pwm_sig(2) <= '0';
                            else
                                pwm_sig(2) <= '1';
                            end if;
                        else
                            pwm_sig(2) <= '0';
                        end if;
                        -- ***************************** PWM2 output finish
                        -- ***************************** PWM3 output start
                        if (up4 < dwn4) then
                            if (tcount >= up4 and tcount < dwn4) then
                                pwm_sig(3) <= '1';
                            else
                                pwm_sig(3) <= '0';
                            end if;
                        elsif (up4 > dwn4) then
                            if (tcount >= dwn4 and tcount < up4) then
                                pwm_sig(3) <= '0';
                            else
                                pwm_sig(3) <= '1';
                            end if;
                        else
                            pwm_sig(3) <= '0';
                        end if;
                        -- ***************************** PWM3 output finish
                        -- ***************************** PWM4 output start
                        if (up5 < dwn5) then
                            if (tcount >= up5 and tcount < dwn5) then
                                pwm_sig(4) <= '1';
                            else
                                pwm_sig(4) <= '0';
                            end if;
                        elsif (up5 > dwn5) then
                            if (tcount >= dwn5 and tcount < up5) then
                                pwm_sig(4) <= '0';
                            else
                                pwm_sig(4) <= '1';
                            end if;
                        else
                            pwm_sig(4) <= '0';
                        end if;
                        -- ***************************** PWM4 output finish
                        -- ***************************** PWM5 output start
                        if (up6 < dwn6) then
                            if (tcount >= up6 and tcount < dwn6) then
                                pwm_sig(5) <= '1';
                            else
                                pwm_sig(5) <= '0';
                            end if;
                        elsif (up6 > dwn6) then
                            if (tcount >= dwn6 and tcount < up6) then
                                pwm_sig(5) <= '0';
                            else
                                pwm_sig(5) <= '1';
                            end if;
                        else
                            pwm_sig(5) <= '0';
                        end if;
                        -- ***************************** PWM5 output finish
                        updatecounter <= (others =>'0');
                        end if;
                        end if;
            end process;
end Behavioral;
But from this file, I manage to generate the outputs as shown in figure above which is not what I was expecting. (As it looks like PWM is getting updated at T1 where I was expecting the Output registers to be updated). I think I am doing something silly around my counter implementation but don't know what and where
The testbench file I used (it might have some issues downstream but I don't think it has any issues around the area where I am having the timing problems at the moment)
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
284
285
286
287
288
289
290
291
292
293
294
295
296
297
298
299
300
301
302
303
304
305
306
307
308
309
310
311
312
313
314
315
316
317
318
319
320
321
322
323
324
325
326
327
328
329
330
331
332
333
334
335
336
337
338
339
340
341
342
343
344
345
346
347
348
349
350
351
352
353
354
355
356
357
358
359
360
361
362
363
364
365
366
367
368
369
370
371
372
373
374
375
376
377
378
379
380
381
382
383
384
385
386
387
388
389
390
391
392
393
394
395
396
397
398
399
400
401
402
403
404
405
406
407
408
409
410
411
412
413
414
415
416
417
418
419
420
421
422
423
424
425
426
427
428
429
430
431
432
433
434
435
436
437
438
439
440
441
442
443
444
445
446
447
448
449
450
451
452
453
454
455
456
457
458
459
460
461
462
463
464
465
466
467
468
469
470
471
472
473
474
475
476
477
478
479
480
481
482
483
484
485
486
487
488
489
490
491
492
493
494
495
496
497
498
499
500
501
502
503
504
505
506
507
508
509
510
511
512
513
514
515
516
517
518
519
520
521
522
523
524
525
526
527
528
529
530
531
532
533
534
535
536
537
538
539
540
541
542
543
544
545
546
547
548
549
550
551
552
553
554
555
556
557
558
559
560
561
562
563
564
565
566
567
568
569
570
571
572
573
574
575
576
577
578
579
580
581
582
583
584
585
586
587
588
589
590
591
592
593
594
595
596
597
598
599
600
601
602
603
604
605
606
607
608
609
610
611
612
613
614
615
616
617
618
619
620
621
622
623
624
625
626
627
628
629
630
631
632
633
634
635
636
637
638
639
640
641
642
643
644
645
646
647
648
649
650
651
652
653
654
655
656
657
658
659
660
661
662
663
664
665
666
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
--USE ieee.numeric_std.ALL;
ENTITY FCBR_main_TB8 IS
END FCBR_main_TB8;
ARCHITECTURE behavior OF FCBR_main_TB8 IS
    -- Component Declaration for the Unit Under Test (UUT)
    COMPONENT main_src
    PORT(
         ISA_ABUS_IN : IN  std_logic_vector(7 downto 0);
         ISA_DBUS_INOUT : INOUT  std_logic_vector(7 downto 0);
         ISA_IOR : IN  std_logic;
         ISA_IOW : IN  std_logic;
         FPGA_OSC : IN  std_logic;
         PWM_OUT : OUT  std_logic_vector(5 downto 0);
         FPGA_DBUS_OUT1 : OUT  std_logic_vector(7 downto 0);
         FPGA_DBUS_OUT2 : OUT  std_logic_vector(7 downto 0);
         FPGA_DBUS_IN1 : IN  std_logic_vector(7 downto 0)
    END COMPONENT;
   --Inputs
   signal ISA_ABUS_IN : std_logic_vector(7 downto 0) := (others => '0');
   signal ISA_IOR : std_logic := '0';
   signal ISA_IOW : std_logic := '0';
   signal FPGA_OSC : std_logic := '0';
   signal FPGA_DBUS_IN1 : std_logic_vector(7 downto 0) := (others => '0');
    --BiDirs
   signal ISA_DBUS_INOUT : std_logic_vector(7 downto 0);
    --Outputs
   signal PWM_OUT : std_logic_vector(5 downto 0);
    signal COUNT_OUT :   STD_LOGIC_VECTOR (15 downto 0);
   signal FPGA_DBUS_OUT1 : std_logic_vector(7 downto 0);
   signal FPGA_DBUS_OUT2 : std_logic_vector(7 downto 0);
   -- No clocks detected in port list. Replace <clock> below with
   -- appropriate port name
   constant FPGA_OSC_period : time := 10 ns; -- 100MHz clock
    -- ADRSSTATS1 -- bits x-x-x-x-x-SC-LP-LC
    constant PWM0ULB: STD_LOGIC_VECTOR (7 downto 0) := X"F4"; -- Start @ 500 = X01F4
    constant PWM0UHB: STD_LOGIC_VECTOR (7 downto 0) := X"01"; -- Start @ 500 = X01F4
    constant PWM0DLB: STD_LOGIC_VECTOR (7 downto 0) := X"E9"; -- Start @ 1001 = X03E9
    constant PWM0DHB: STD_LOGIC_VECTOR (7 downto 0) := X"03"; -- Start @ 1001 = X03E9
    constant PWM1ULB: STD_LOGIC_VECTOR (7 downto 0) := X"9B"; -- Start @ 667 = X029B
    constant PWM1UHB: STD_LOGIC_VECTOR (7 downto 0) := X"02"; -- Start @ 667 = X029B
    constant PWM1DLB: STD_LOGIC_VECTOR (7 downto 0) := X"A6"; -- Start @ 166 = X00A6
    constant PWM1DHB: STD_LOGIC_VECTOR (7 downto 0) := X"00"; -- Start @ 166 = X00A6
    constant PWM2ULB: STD_LOGIC_VECTOR (7 downto 0) := X"43"; -- Start @ 835 = X0343
    constant PWM2UHB: STD_LOGIC_VECTOR (7 downto 0) := X"03"; -- Start @ 835 = X0343
    constant PWM2DLB: STD_LOGIC_VECTOR (7 downto 0) := X"38"; -- Start @ 1336 = X0538
    constant PWM2DHB: STD_LOGIC_VECTOR (7 downto 0) := X"05"; -- Start @ 1336 = X0538
    constant PWM3ULB: STD_LOGIC_VECTOR (7 downto 0) := X"EA"; -- Start @ 1002 = X03EA
    constant PWM3UHB: STD_LOGIC_VECTOR (7 downto 0) := X"03"; -- Start @ 1002 = X03EA
    constant PWM3DLB: STD_LOGIC_VECTOR (7 downto 0) := X"DF"; -- Start @ 1503 = X05DF
    constant PWM3DHB: STD_LOGIC_VECTOR (7 downto 0) := X"05"; -- Start @ 1503 = X05DF
    constant PWM4ULB: STD_LOGIC_VECTOR (7 downto 0) := X"91"; -- Start @ 1169 = X0491
    constant PWM4UHB: STD_LOGIC_VECTOR (7 downto 0) := X"04"; -- Start @ 1169 = X0491
    constant PWM4DLB: STD_LOGIC_VECTOR (7 downto 0) := X"86"; -- Start @ 1670 = X0686
    constant PWM4DHB: STD_LOGIC_VECTOR (7 downto 0) := X"06"; -- Start @ 1670 = X0686
    constant PWM5ULB: STD_LOGIC_VECTOR (7 downto 0) := X"38"; -- Start @ 1336 = X0538
    constant PWM5UHB: STD_LOGIC_VECTOR (7 downto 0) := X"05"; -- Start @ 1336 = X0538
    constant PWM5DLB: STD_LOGIC_VECTOR (7 downto 0) := X"2D"; -- Start @ 1837 = X072D
    constant PWM5DHB: STD_LOGIC_VECTOR (7 downto 0) := X"07"; -- Start @ 1837 = X072D
    constant STATLC: STD_LOGIC_VECTOR (7 downto 0) := X"01"; -- Status register has LC bit set
    constant STATLP: STD_LOGIC_VECTOR (7 downto 0) := X"02"; -- Status register has LP bit set
    constant STATSC: STD_LOGIC_VECTOR (7 downto 0) := X"04"; -- Status register has SC bit set
    constant PERIODLB: STD_LOGIC_VECTOR (7 downto 0) := X"EA"; -- Start @ 1002 = X03EA
    constant PERIODHB: STD_LOGIC_VECTOR (7 downto 0) := X"03"; -- Start @ 1002 = X03EA
BEGIN
    -- Instantiate the Unit Under Test (UUT)
   uut: main_src PORT MAP (
          ISA_ABUS_IN => ISA_ABUS_IN,
          ISA_DBUS_INOUT => ISA_DBUS_INOUT,
          ISA_IOR => ISA_IOR,
          ISA_IOW => ISA_IOW,
          PWM_OUT => PWM_OUT,
             COUNT_OUT => COUNT_OUT,
          FPGA_DBUS_OUT1 => FPGA_DBUS_OUT1,
          FPGA_DBUS_OUT2 => FPGA_DBUS_OUT2,
          FPGA_DBUS_IN1 => FPGA_DBUS_IN1
   -- Clock process definitions
   FPGA_OSC_process :process
   begin
        FPGA_OSC <= '0';
        wait for FPGA_OSC_period/2;
        FPGA_OSC <= '1';
   end process;
   -- Stimulus process
   stim_proc: process
   begin
        wait for FPGA_OSC_period*10;
        FPGA_DBUS_IN1 <= PWM0ULB;
        ISA_IOW <= '1';
      ISA_IOR <= '0';   -- nothing should happen for above
      ISA_DBUS_INOUT<="ZZZZZZZZ";
        wait for FPGA_OSC_period*2;
        --******************* Write is enabled now onwards
        ISA_IOW <= '0'; -- write cycle enabled
      ISA_IOR <= '1';
        --******************* Load PERIOD LOW byte
      ISA_ABUS_IN <= ADDRESSFQL;
      ISA_DBUS_INOUT <= X"0A";
        --******************* Load PERIOD HIGH byte
        ISA_ABUS_IN <= ADDRESSFQH;
      ISA_DBUS_INOUT <= X"00";
        --******************* Load pwm0 UP LOW byte
        ISA_DBUS_INOUT <= X"04";
      ISA_ABUS_IN <= ADDRESSUL1;
        --******************* Load pwm0 UP HIGH byte
        ISA_ABUS_IN <= ADDRESSUH1;
        --******************* Load pwm0 DOWN LOW byte
        ISA_DBUS_INOUT <= X"07";
      ISA_ABUS_IN <= ADDRESSDL1;
        --******************* Load pwm0 DOWN HIGH byte
        ISA_ABUS_IN <= ADDRESSDH1;
        --******************* Load pwm1 UP LOW byte
      ISA_ABUS_IN <= ADDRESSUL2;
        --******************* Load pwm1 UP HIGH byte
        ISA_ABUS_IN <= ADDRESSUH2;
        --******************* Load pwm1 DOWN LOW byte
      ISA_ABUS_IN <= ADDRESSDL2;
        --******************* Load pwm1 DOWN HIGH byte
        ISA_ABUS_IN <= ADDRESSDH2;
        --******************* Load pwm2 UP LOW byte
      ISA_ABUS_IN <= ADDRESSUL3;
        --******************* Load pwm2 UP HIGH byte
        ISA_ABUS_IN <= ADDRESSUH3;
        --******************* Load pwm2 DOWN LOW byte
        ISA_DBUS_INOUT <= X"08";
      ISA_ABUS_IN <= ADDRESSDL3;
        --******************* Load pwm2 DOWN HIGH byte
        ISA_ABUS_IN <= ADDRESSDH3;
        --******************* Load pwm3 UP LOW byte
      ISA_ABUS_IN <= ADDRESSUL4;
        --******************* Load pwm3 UP HIGH byte
        ISA_ABUS_IN <= ADDRESSUH4;
        --******************* Load pwm3 DOWN LOW byte
      ISA_ABUS_IN <= ADDRESSDL4;
        --******************* Load pwm3 DOWN HIGH byte
        ISA_ABUS_IN <= ADDRESSDH4;
        --******************* Load pwm4 UP LOW byte
        ISA_DBUS_INOUT <= X"09";
      ISA_ABUS_IN <= ADDRESSUL5;
        --******************* Load pwm4 UP HIGH byte
        ISA_ABUS_IN <= ADDRESSUH5;
        --******************* Load pwm4 DOWN LOW byte
      ISA_ABUS_IN <= ADDRESSDL5;
        --******************* Load pwm4 DOWN HIGH byte
        ISA_ABUS_IN <= ADDRESSDH5;
            --******************* Load pwm5 UP LOW byte
      ISA_ABUS_IN <= ADDRESSUL6;
        --******************* Load pwm5 UP HIGH byte
        ISA_ABUS_IN <= ADDRESSUH6;
        --******************* Load pwm5 DOWN LOW byte
      ISA_ABUS_IN <= ADDRESSDL6;
        --******************* Load pwm5 DOWN HIGH byte
        ISA_ABUS_IN <= ADDRESSDH6;
        --******************* Load STATUS REGISTER with all 4 members 'SET' LC, L, & SC
        ISA_ABUS_IN <= ADRSSTATS1;
      ISA_DBUS_INOUT <="00001111";
        wait for FPGA_OSC_period*1;
        --******************* Set Address bus to an invalid Address
    --  ISA_ABUS_IN <= X"FF";
        wait for FPGA_OSC_period*3;
        -- Reading the Status register
        ISA_IOW <= '1';
      ISA_IOR <= '0';   -- Read is Enabled
        wait for FPGA_OSC_period*20;
      ISA_IOR <= '1';
        wait for FPGA_OSC_period*5;
    --  wait for FPGA_OSC_period*2;
    --  wait for FPGA_OSC_period*20;
        ISA_IOW <= '1';
        wait for FPGA_OSC_period*4;
      ISA_IOR <= '1';
        -- ***** ALTERING THE PERIOD AGAIN HERE BUT IT SHOULD NOY AFFECT THE PWM DUE TO LATCH USED
        --******************* Load pwm0 UP LOW byte with a FAULTY VALUE > TPERIOD
--      ISA_DBUS_INOUT <= X"0A";
--      ISA_ABUS_IN <= ADDRESSUL1;
--      wait for FPGA_OSC_period*4;
--      --******************* Load pwm0 UP HIGH byte
--      ISA_ABUS_IN <= ADDRESSUH1;
--      ISA_DBUS_INOUT <= X"00";
        -- ********************************************************************* FAULTY VALUE > TPERIOD ENDS HERE
        -- ******************************************************************** FAULTY VALUE STAUSREG LOADED & PWM SHOULD GO OFF - END
        --******************* Load STATUS REGISTER with  two members 'SET' & LC, LP = 0
        ISA_DBUS_INOUT <=X"FF";
--      ISA_DBUS_INOUT <="00001101";
        ISA_DBUS_INOUT <= X"02";
        ISA_DBUS_INOUT <= X"03";
        ISA_DBUS_INOUT <= X"05";
        -- **** Up till this point Pwm0 : UP & DOWN sequence is:
        -- UP       &       DOWN
        -- 4        &       7
        -- 2        &       4
        -- 4        &       2
        -- 3        &       8
        -- 5        &       5
        -- 3        &       8
        wait for FPGA_OSC_period*50;
        ISA_DBUS_INOUT <= X"0A"; -- **************************INVALID  VALUE LOADED
        wait for FPGA_OSC_period*50; -- Wait to see if it affects the Output - It should not
--      wait for FPGA_OSC_period*10000;
        assert false
        report "NS Simulation Completed"
        severity failure;
      -- hold reset state for 100 ns.
   end process;
END;
Some help please
Sorry, but this is a mess. You seem to have made a relatively simple task a horrendous clump of IF statements all in a single process. I suggest you start over, taking several suggestions into account.
1) Break this up into individual processes. There’s nothing functionally wrong with using one process, but it makes it REALLY hard to understand and debug.
2) use state machine(s)
Also, you mention that you specify on time, off time, and period. If you specify any two of those, you’ve defined the third. You don’t need all three.
Reactions: eengr
    eengr
