LIBRARY IEEE;
USE IEEE.std_logic_1164.ALL;
USE IEEE.std_logic_unsigned.ALL;
USE STD.TEXTIO.ALL;
USE IEEE.std_logic_TEXTIO.ALL;
ENTITY std_logic_ram IS
PORT (address : IN std_logic_vector;
datain : IN std_logic_vector; dataout : OUT std_logic_vector;
cs, rwbar : IN std_logic; opr : IN BOOLEAN);
END ENTITY std_logic_ram;
ARCHITECTURE behavioral OF std_logic_ram IS
TYPE mem IS ARRAY (NATURAL RANGE <>, NATURAL RANGE <>) of std_logic;
PROCEDURE init_mem (VARIABLE memory: OUT mem;
CONSTANT datafile: STRING) IS
FILE stddata : TEXT;
VARIABLE l : LINE;
VARIABLE data : std_logic_vector(memory'RANGE(2));
BEGIN
FILE_OPEN (stddata, datafile, READ_MODE);
FOR i IN memory'RANGE(1) LOOP
READLINE (stddata, l); READ (l, data);
FOR j IN memory'REVERSE_RANGE(2) LOOP
memory (i,j) := data(j);
END LOOP;
END LOOP;
END PROCEDURE init_mem;
PROCEDURE dump_mem (VARIABLE memory: IN mem;
VARIABLE stdvalue : std_logic;
VARIABLE l : LINE;
BEGIN
FILE_OPEN (stddata, datafile, WRITE_MODE);
stdvalue := memory (i, j);
WRITE (l, stdvalue);
END LOOP;
WRITELINE (stddata, l);
END LOOP;
END PROCEDURE dump_mem;
BEGIN
PROCESS
CONSTANT memsize : INTEGER := 2**address'LENGTH;
VARIABLE memory : mem (0 TO memsize-1, datain'RANGE);
BEGIN
id: IF opr'EVENT THEN
IF opr=TRUE THEN init_mem (memory, "memdata.dat");
ELSE dump_mem (memory, "memdump.dat");
END IF;
END IF;
wr: IF cs = '1' THEN
IF rwbar = '0' THEN -- Writing
FOR i IN dataout'RANGE LOOP
memory (conv_integer (address), i) := datain (i);
END LOOP;
ELSE -- Reading
FOR i IN datain'RANGE LOOP
dataout (i) <= memory (conv_integer (address), i);
END LOOP;
END IF;
END IF;
WAIT ON cs, rwbar, address, datain, opr;
END PROCESS;
END ARCHITECTURE behavioral;
