VHDL compilation error "Identifier "unsigned" is not directly visible"
engr_joni_ee
Advanced Member level 3
I get an error (Identifier "unsigned" is not directly visible) while converting std_logic_vector to integer.
The signal and variable definition.
signal s_temp : std_logic_vector (7 downto 0);
variable i_temp : integer;
The libraries
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
Conversion
i_temp := to_integer(unsigned(s_temp));
Re: VHDL compilation error "Identifier "unsigned" is not directly visible"
std_logic_arith and numeric_std both define an unsigned type. So the compiler doesnt know which to use and hence uses neither (and you get the error).
The simple answer is to delete std_logic_arith as it is a non-standard VHDL library (std_logic_unsigned is also non-standard). std_logic_arith really should be a dead package.
the long answer is to be explicit about which one you mean:
i_temp := to_integer(ieee.numeric_std.unsigned(s_temp));
but who wants to do all that extra typing! Just delete std_logic_arith and forget the package ever existed.
Anyone using std_logic_arith is 25 years behind the times (numeric_std was released in 1993!)
std_logic_unsigned does have uses (although non-standard) but can be replaced by using numeric_std_unsigned (released 10 years ago!)
