comparison_tree : process ( IN_CLOCK , IN_RESET_ASYNCHRONOUS ) is
begin
if IN_RESET_ASYNCHRONOUS = '1' then
stage_0_vote <= ( others => 0 ) ;
stage_1_vote <= ( others => 0 ) ;
stage_2_vote <= ( others => 0 ) ;
stage_3_vote <= ( others => 0 ) ;
stage_4_vote <= ( others => 0 ) ;
stage_5_vote <= ( others => 0 ) ;
stage_6_vote <= ( others => 0 ) ;
stage_7_vote <= 0 ;
elsif rising_edge ( IN_CLOCK ) then
if IN_RESET_SYNCHRONOUS = '1' then
stage_7_vote <= 0 ;
else
for index in 0 to 63
loop
if input ( 2 * index ) > input ( 2 * index + 1 ) then
stage_0_vote ( index ) <= 2 * index ;
else
stage_0_vote ( index ) <= ( 2 * index + 1 ) ;
end if ;
end loop ;
for index in 0 to 31
loop
if stage_0_vote ( 2 * index ) > stage_0_vote ( 2 * index + 1 ) then
stage_1_vote ( index ) <= stage_0_vote ( 2 * index ) ;
else
stage_1_vote ( index ) <= stage_0_vote ( 2 * index + 1 ) ;
end if ;
end loop ;
for index in 0 to 15
loop
if stage_1_vote ( 2 * index ) > stage_1_vote ( 2 * index + 1 ) then
stage_2_vote ( index ) <= stage_1_vote ( 2 * index ) ;
else
stage_2_vote ( index ) <= stage_1_vote ( 2 * index + 1 ) ;
end if ;
end loop ;
for index in 0 to 7
loop
if stage_2_vote ( 2 * index ) > stage_2_vote ( 2 * index + 1 ) then
stage_3_vote ( index ) <= stage_2_vote ( 2 * index ) ;
else
stage_3_vote ( index ) <= stage_2_vote ( 2 * index + 1 ) ;
end if ;
end loop ;
for index in 0 to 3
loop
if stage_3_vote ( 2 * index ) > stage_3_vote ( 2 * index + 1 ) then
stage_4_vote ( index ) <= stage_3_vote ( 2 * index ) ;
else
stage_4_vote ( index ) <= stage_3_vote ( 2 * index + 1 ) ;
end if ;
end loop ;
for index in 0 to 1
loop
if stage_4_vote ( 2 * index ) > stage_4_vote ( 2 * index + 1 ) then
stage_5_vote ( index ) <= stage_4_vote ( 2 * index ) ;
else
stage_5_vote ( index ) <= stage_4_vote ( 2 * index + 1 ) ;
end if ;
end loop ;
for index in 0 to 1
loop
if stage_5_vote ( 2 * index ) > stage_5_vote ( 2 * index + 1 ) then
stage_6_vote ( index ) <= stage_5_vote ( 2 * index ) ;
else
stage_6_vote ( index ) <= stage_5_vote ( 2 * index + 1 ) ;
end if ;
end loop ;
if stage_6_vote ( 0 ) > stage_6_vote ( 1 ) then
stage_7_vote <= stage_6_vote ( 0 ) ;
else
stage_7_vote <= stage_6_vote ( 1 ) ;
end if ;
end if ;
end if ;
end process comparison_tree ;
128 words - every clock of which I have to find the location of the highest.What's the dataflow?
-- This is more generic. It relies on the synthesis tools doing the right thing.
-- I haven't synthesized this yet. You should compare it to other styles.
-- Historically, tools have treated sequentially numbered names as a bus. This
-- is not the case for "stages". Likewise using variables in the loop for indexing
-- probably synthesizes fine, but maybe not. You can always ensure it works by
-- creating constant integer_arrays for them.
-- I will assume a power of two input. normalize to this if needed.
signal stages : element_array(2*N-1-1 downto 0);
constant kStages : integer := ceil_log2(N); -- find some version of this common function
function stage(x : element_array) return element_array is
variable x_nml : element_array(x'length-1 downto 0) := x;
variable ret : element_array(x'length/2 -1 downto 0);
begin
for i in ret'range loop
if x_nml(2*i+1) > x_nml(2*i) then
ret(i) := x_nml(2*i+1);
else
ret(i) := x_nml(2*i);
end if;
end loop;
return ret;
end function;
process (clk, rst) is
variable idx_low : integer := 0;
variable idx_size : integer := N;
begin
if rst = '1' then
stages := (others => kElementZero);
else if rising_edge(clk) then
idx_low := 0;
idx_size := N;
for i in 1 to kStages loop
stages(idx_low + idx_size/2 -1 downto idx_low) <= stage(stages(idx_low+idx_size-1 downto idx_low));
idx_low := idx_low + idx_size/2;
idx_size := idx_size/2;
end loop;
end if;
end process;
Can you show an example of what you mean ?Another generic method would use if-generate/for-generate to recursively generate components. But that generates a lot of components and probably isn't as sim-friendly.
What is the clock frequency?128 words - every clock of which I have to find the location of the highest.
entity comparison_tree is
generic
NUMBER_OF_WORDS : positive := 128 ;
WIDTH_WORD : positive := 12
port
IN_CLOCK : in std_logic ; -- Global clock.
IN_DATA : in generic_1d_unsigned_array ( 0 to NUMBER_OF_WORDS - 1 ) ( WIDTH_WORD - 1 downto 0 ) ;
IN_RESET_ASYNCHRONOUS : in std_logic ; -- Asynchronous Reset.
IN_RESET_SYNCHRONOUS : in std_logic ; -- Synchronous Reset.
OUT_SOURCE : out unsigned ( positive ( ceil ( log2 ( real ( NUMBER_OF_WORDS ) ) ) ) - 1 downto 0 )
end entity comparison_tree ;
architecture rtl_comparison_tree of comparison_tree is
signal stage_0_result : generic_1d_unsigned_array ( 0 to NUMBER_OF_WORDS / 2 - 1 ) ( WIDTH_WORD - 1 downto 0 ) ;
signal stage_1_result : generic_1d_unsigned_array ( 0 to NUMBER_OF_WORDS / 4 - 1 ) ( WIDTH_WORD - 1 downto 0 ) ;
signal stage_2_result : generic_1d_unsigned_array ( 0 to NUMBER_OF_WORDS / 8 - 1 ) ( WIDTH_WORD - 1 downto 0 ) ;
signal stage_3_result : generic_1d_unsigned_array ( 0 to NUMBER_OF_WORDS / 16 - 1 ) ( WIDTH_WORD - 1 downto 0 ) ;
signal stage_4_result : generic_1d_unsigned_array ( 0 to NUMBER_OF_WORDS / 32 - 1 ) ( WIDTH_WORD - 1 downto 0 ) ;
signal stage_5_result : generic_1d_unsigned_array ( 0 to NUMBER_OF_WORDS / 64 - 1 ) ( WIDTH_WORD - 1 downto 0 ) ;
signal stage_6_result : unsigned ( WIDTH_WORD - 1 downto 0 ) ;
signal stage_0_source : generic_1d_unsigned_array ( 0 to NUMBER_OF_WORDS / 2 - 1 ) ( positive ( ceil ( log2 ( real ( NUMBER_OF_WORDS ) ) ) ) - 1 downto 0 ) ;
signal stage_1_source : generic_1d_unsigned_array ( 0 to NUMBER_OF_WORDS / 4 - 1 ) ( positive ( ceil ( log2 ( real ( NUMBER_OF_WORDS ) ) ) ) - 1 downto 0 ) ;
signal stage_2_source : generic_1d_unsigned_array ( 0 to NUMBER_OF_WORDS / 8 - 1 ) ( positive ( ceil ( log2 ( real ( NUMBER_OF_WORDS ) ) ) ) - 1 downto 0 ) ;
signal stage_3_source : generic_1d_unsigned_array ( 0 to NUMBER_OF_WORDS / 16 - 1 ) ( positive ( ceil ( log2 ( real ( NUMBER_OF_WORDS ) ) ) ) - 1 downto 0 ) ;
signal stage_4_source : generic_1d_unsigned_array ( 0 to NUMBER_OF_WORDS / 32 - 1 ) ( positive ( ceil ( log2 ( real ( NUMBER_OF_WORDS ) ) ) ) - 1 downto 0 ) ;
signal stage_5_source : generic_1d_unsigned_array ( 0 to NUMBER_OF_WORDS / 64 - 1 ) ( positive ( ceil ( log2 ( real ( NUMBER_OF_WORDS ) ) ) ) - 1 downto 0 ) ;
signal stage_6_source : unsigned ( positive ( ceil ( log2 ( real ( NUMBER_OF_WORDS ) ) ) ) - 1 downto 0 ) ;
begin
OUT_SOURCE <= stage_6_source ;
begin
stage_0_result <= ( others => ( others => '0' ) ) ;
stage_1_result <= ( others => ( others => '0' ) ) ;
stage_2_result <= ( others => ( others => '0' ) ) ;
stage_3_result <= ( others => ( others => '0' ) ) ;
stage_4_result <= ( others => ( others => '0' ) ) ;
stage_5_result <= ( others => ( others => '0' ) ) ;
stage_6_result <= ( others => '0' ) ;
else
for index in 0 to NUMBER_OF_WORDS / 2 - 1
loop
if IN_DATA ( 2 * index ) > IN_DATA ( 2 * index + 1 ) then
stage_0_result ( index ) <= IN_DATA ( 2 * index ) ;
stage_0_source ( index ) <= to_unsigned ( 2 * index , positive ( ceil ( log2 ( real ( NUMBER_OF_WORDS ) ) ) ) ) ;
else
stage_0_result ( index ) <= IN_DATA ( 2 * index + 1 ) ;
stage_0_source ( index ) <= to_unsigned ( 2 * index + 1 , positive ( ceil ( log2 ( real ( NUMBER_OF_WORDS ) ) ) ) ) ;
end if ;
end loop ;
for index in 0 to NUMBER_OF_WORDS / 4 - 1
loop
if stage_0_result ( 2 * index ) > stage_0_result ( 2 * index + 1 ) then
stage_1_result ( index ) <= stage_0_result ( 2 * index ) ;
stage_1_source ( index ) <= stage_0_source ( 2 * index ) ;
else
stage_1_result ( index ) <= stage_0_result ( 2 * index + 1 ) ;
stage_1_source ( index ) <= stage_0_source ( 2 * index + 1 ) ;
end if ;
end loop ;
for index in 0 to NUMBER_OF_WORDS / 8 - 1
loop
if stage_1_result ( 2 * index ) > stage_1_result ( 2 * index + 1 ) then
stage_2_result ( index ) <= stage_1_result ( 2 * index ) ;
stage_2_source ( index ) <= stage_1_source ( 2 * index ) ;
else
stage_2_result ( index ) <= stage_1_result ( 2 * index + 1 ) ;
stage_2_source ( index ) <= stage_1_source ( 2 * index + 1 ) ;
end if ;
end loop ;
for index in 0 to NUMBER_OF_WORDS / 16 - 1
loop
if stage_2_result ( 2 * index ) > stage_2_result ( 2 * index + 1 ) then
stage_3_result ( index ) <= stage_2_result ( 2 * index ) ;
stage_3_source ( index ) <= stage_2_source ( 2 * index ) ;
else
stage_3_result ( index ) <= stage_2_result ( 2 * index + 1 ) ;
stage_3_source ( index ) <= stage_2_source ( 2 * index + 1 ) ;
end if ;
end loop ;
for index in 0 to NUMBER_OF_WORDS / 32 - 1
loop
if stage_3_result ( 2 * index ) > stage_3_result ( 2 * index + 1 ) then
stage_4_result ( index ) <= stage_3_result ( 2 * index ) ;
stage_4_source ( index ) <= stage_3_source ( 2 * index ) ;
else
stage_4_result ( index ) <= stage_3_result ( 2 * index + 1 ) ;
stage_4_source ( index ) <= stage_3_source ( 2 * index + 1 ) ;
end if ;
end loop ;
for index in 0 to NUMBER_OF_WORDS / 64 - 1
loop
if stage_4_result ( 2 * index ) > stage_4_result ( 2 * index + 1 ) then
stage_5_result ( index ) <= stage_4_result ( 2 * index ) ;
stage_5_source ( index ) <= stage_4_source ( 2 * index ) ;
else
stage_5_result ( index ) <= stage_4_result ( 2 * index + 1 ) ;
stage_5_source ( index ) <= stage_4_source ( 2 * index + 1 ) ;
end if ;
end loop ;
if stage_5_result ( 0 ) > stage_5_result ( 1 ) then
stage_6_result <= stage_5_result ( 0 ) ;
stage_6_source <= stage_5_source ( 0 ) ;
else
stage_6_result <= stage_5_result ( 1 ) ;
stage_6_source <= stage_5_source ( 1 ) ;
end if ;
end if ;
end if ;
end architecture rtl_comparison_tree ;
The "steps" topology ThisIsNotSam suggested would require a number of registers that's equivalent to the sum of an Arithmetic Sequence from 1 to 128 - I.E: 1+2+...+128 registers = 8256
Yes it would, and that is pretty acceptable in most cases. 8k registers is chump change in the world of multi-million gate designs.
FYI this is an FPGA design not a multi-million gate ASIC design.
Even though 8k registers isn't a terribly large number of FFs to use for one module, it is a significant chunk of resources when you only have 400k in a medium sized FPGA (that's 2% of the total in one module).
Of course if this is done in a large Virtex/Stratix part or an Ultrascale part then yes, I would agree it is chump change.
When I said "register" I meant each register is actually a vector of DFFs.Yes it would, and that is pretty acceptable in most cases. 8k registers is chump change in the world of multi-million gate designs.
