vhdl coding for pattern generation
vishushru
Newbie level 3
vhdl code to generate incremental pattern in serial manner using counter.
please help me out
ads-ee
Super Moderator
Staff member
USA
So you need to send the contents of a counter as a serial stream? Is this supposed to be done LSB or MSB first?
I won't code this for you but here is the basic logic you will need to do this.
1) create a counter with an enable count input (this is the incrementing pattern you are sending)
2) create a counter that counts the bits sent (this is a counter that is big enough to count the width of the incrementing pattern counter)
3) make a loadable shift register to serially shift the loaded value out either LSB or MSB first.
4) combine the above stuff along with a check for the last bit sent to increment the pattern counter.
5) write a testbench to verify your design.
If you've already done some of this work already and are just having problems then post the code you've already written to get help.
vishushru
Newbie level 3
i wrote a vhdl code for 8 bit counter what i hav to do next
ads-ee
Super Moderator
Staff member
USA
Steps 2 thru 5 in my previous post.
Let me add that step 4 also involves creating the top level file which either has instances of other code or the code of each function in that top file.
