Hello,
I hava a VHDL module called hello_med1.vhd.The codes are as follow:
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.numeric_std.all;
library zpu;
use zpu.zpupkg.all;
entity Hello_Med1 is
generic(
WORD_SIZE : natural:=32; -- 32 bits data path
D_CARE_VAL : std_logic:='0'; -- Fill value, I got better results with it
CLK_FREQ : positive:=50; -- 50 MHz clock
BRATE : positive:=115200; -- RS-232 baudrate
ADDR_W : natural:=18; -- 18 bits address space=256 kB, 128 kB I/O
BRAM_W : natural:=14); -- 14 bits RAM space=16 kB
port(
clk_i : in std_logic; -- CPU clock
rst_i : in std_logic; -- Reset
rs232_tx_o : out std_logic; -- UART Tx
rs232_rx_i : in std_logic); -- UART Rx
constant BRD_PB1_I : string:="D19"; -- SWITCH8==S2
constant BRD_CLK1_I : string:="AA12"; -- 50 MHz clock
--constant BRD_CLK1_I : string:="AB12"; -- 40 MHz clock
-- UART: direct 1:1 cable
constant BRD_TX_O : string:="L4"; -- UART 1 (J1) TXD1 DB9 pin 2
constant BRD_RX_I : string:="L3"; -- UART 1 (J1) RXD1 DB9 pin 3
-- Pinout --
attribute LOC : string;
attribute IOSTANDARD : string;
constant IOSTD : string:="LVTTL";
attribute LOC of rst_i : signal is BRD_PB1_I;
attribute IOSTANDARD of rst_i : signal is IOSTD;
attribute LOC of clk_i : signal is BRD_CLK1_I;
attribute LOC of rs232_tx_o : signal is BRD_TX_O;
attribute IOSTANDARD of rs232_tx_o : signal is IOSTD;
attribute LOC of rs232_rx_i : signal is BRD_RX_I;
attribute IOSTANDARD of rs232_rx_i : signal is IOSTD;
end entity Hello_Med1;
architecture FPGA of Hello_Med1 is
component ZPU_Med1 is
generic(
D_CARE_VAL : std_logic:='X'; -- Fill value
BRATE : positive:=9600; -- RS232 baudrate
BRAM_W : natural:=15); -- 15 bits RAM space=32 kB
port(
break_o : out std_logic; -- Break executed
dbg_o : out zpu_dbgo_t; -- Debug info
end component ZPU_Med1;
begin
zpu : ZPU_Med1
generic map(
WORD_SIZE => WORD_SIZE, D_CARE_VAL => D_CARE_VAL,
CLK_FREQ => CLK_FREQ, BRATE => BRATE, ADDR_W => ADDR_W,
BRAM_W => BRAM_W)
port map(
clk_i => clk_i, rst_i => rst_i, rs232_tx_o => rs232_tx_o,
rs232_rx_i => rs232_rx_i, dbg_o => open);
end architecture FPGA; -- Entity: Hello_Med1
I have another VHDL module which called ZPU_Med1.vhd.Now want to include my previous VHDL module, hello_med1.vhd in my top-level design entity.Should i include along my ZPU_Med1.vhd?? This has been confusing me since i already have ZPU_Med1 in my hello_med1.vhd..Does this mean that ZPU_Med1.vhd is actually already in my hello_med1.vhd??
Any help i greatly appreciate.Thx
Regards,
Bruno
