kyawsoelwin
Junior Member level 2
vhdl code for counter
Pls check it out this input wave vector file.
I want to design a counter which starts counting at which set pin=1 and positive rise edge of clock.
And Counting reset again next cycle of set pin.
if i used the code
the counter counts only set cycle.
if i used the code
If i tried again like that counting and reset is ok but .. it has no synchronization
the counting ignores the clk edges inside the set high cycle (set='1')
I tried a few couple of days. pls help me and give some idea.
thanks in advance for your time.
Regards,
The waveform of this problem's solution is as follow . pls click and see.
But I cann't design in VHDL to get this solution. If someone expert in VHDL , pls kindly help me and give some idea.
Thanks and regards again.
if i used the code
if (set=1) then
if (clk'event and clk='1')
if i used the code
if (clk'evnt and clk='1')
cnt:=cnt+1; -- for counting the clk
if set='1' then
cnt=0 ---counter reset
Regards,
