VHDL code for T-Flip Flops
e.the
Newbie level 2
Newbie level 2
hi,
I want to write a VHDL code for this design. can you help me with that?
regards
thats the issue. i'm not sure this is what i need, but thanx.
check this out :
[syntax=vhdl]
library ieee;
use ieee.std_logic_1164.all;
entity  tffs is
  generic (
    n : natural := 4);
  port (
    Clk      : in  std_logic;
    clr_n      : in std_logic;
    e   : in  std_logic;
    q   : out std_logic
end entity tffs;
architecture Bhv of tffs is
dn, qn, qno : std_logic_vector(0 to n-1);
begin
 --in
 dn(0) <= e;
 --combinatoric
 gen_more_then_2ffs : if n >=2 generate
   gen_i : for i in 1 to n-1 generate
     dn(i) <= dn(i-1) and qno(i-1);
   end generate gen_i;
 end generate gen_more_then_2ffs;
 --out
 q <= qno(n-1);
 -- tffs
 gen_in : for i in 0 to n-1 generate
   p_clk : process(clk)
   begin
     if rising_edge(clk) then
	   if (dn(i) = '1') then
	     qn(i) <= not qn(i);
	   end if;
     end if;
   end process p_clk;
 qno(i) <= qn(i) when clr_n = '1' else '0';
 end generate gen_in;
end Bhv;
[/syntax]
-- D-Flip FLop
library IEEE;
use IEEE.STD_LOGIC_1164.all;
ENTITY dff IS
  PORT (
        clock  : IN  std_logic;
        reset  : IN  std_logic;
	    d      : IN  std_logic;
        q      : BUFFER std_logic
END ENTITY dff;
ARCHITECTURE rtl OF dff IS
BEGIN
PROCESS ( clock, reset )
BEGIN
  IF ( reset = '0' ) THEN
     q    <= '0';
  ELSIF ( clock = '1' AND clock'EVENT) THEN
     q  <= d;
  END IF;
END PROCESS;
END rtl;
-- T-Flip Flop
library IEEE;
use work.dff;
ENTITY tff IS
  PORT (
        clear : IN     std_logic;
		t     : INOUT  std_logic;
END ENTITY tff;
ARCHITECTURE rtl_tff OF tff IS
COMPONENT dff
  PORT (
        d     : IN  std_logic;
END COMPONENT;
BEGIN
dff_inst : dff PORT MAP
                         clock => clock,
                         reset => clear,
	                     d     => NOT q,
                         q     => q
END rtl_tff;
library IEEE;
use work.tff;
ENTITY ckt IS
  PORT (
        enable : IN std_logic;
		  q_out  : BUFFER std_logic
END ENTITY ckt;
ARCHITECTURE rtl_ckt OF ckt IS
COMPONENT tff
  PORT (
END COMPONENT;
SIGNAL t_2,t_3,t_4,q,q2,q3 : std_logic;
BEGIN
tff_1 : tff PORT MAP (
                      clock => clock,
							 clear => clear,
							 t     => enable,
							 q     => q
t_2 <= enable AND q;
tff_2 : tff PORT MAP (
	                   clock => clock,
							 clear => clear,
							 t     => t_2,
							 q     => q2
t_3 <= t_2 AND q2;
tff_3 : tff PORT MAP (
	                   clock => clock,
							 clear => clear,
							 t     => t_3,
							 q     => q3
t_4 <= t_3 AND q3;
tff_4 : tff PORT MAP (
	                   clock => clock,
							 clear => clear,
							 t     => t_4,
							 q     => q_out
END rtl_ckt;
