VHDL code for SR flip-flop built with NOR gates
shaiko
I know this is a simple 2-1 mux :
A <= '0' when X = '1' else '1'
But what does the following generate ?
A <= '0' when X = '1' else '1' when Y = '1' ;
How can you rewrite it ?
Re: unfamiliar VHDL code
I am not a VHDL expert (i am much more used to Verilog) but i belive that some states are missing, so it got undefined behavior.
So what happens when Y and X are 0? Undefined... it should be defined;
I belive the right should be:
A <= '0' WHEN X = '1' ELSE,
       '1' WHEN Y = '1' ELSE,
       <SOMETHING>;
Cya
Reactions: shaiko
    shaiko
       <SOMETHING>;
Cya
It is defined behavior, the definition being from the LRM. If there is no update for a signal then it simply maintains the current state. Which is why std_match properly classified it as an SR latch (with reset taking precedence). If neither X or Y (analogous to R and S) are set, then the output A retains its present state, whatever that is.
I suspect the behavior is the same for Verilog and is also part of the Verilog LRM.
Kevin Jennings
Reactions: shaiko
    shaiko
K-J, std_match
You're saying that it's a transparent SR latch ?
---------- Post added at 22:00 ---------- Previous post was at 21:58 ----------
I was surprised to see pass the parsing check.
Most latches/FFs I've seen are described in a process.
K-J, std_match
It's an SR latch...a transparent latch generally refers to a latch where you have a latch enable rather than a clock. I'm not sure what you mean by transparent SR latch, but I'm guessing that you mean it to be a latch that doesn't have an edge triggered storage. On that assumption, the original code that was posted was...
This form must be a concurrent statement, therefore it is not inside any process therefore it must be describing an SR latch not any edge triggered storage.
I'm not sure what parsing check you're referring to. There is nothing invalid about the code so there is no reason why it won't make it through any compiler. However, whether you should or should not use such a thing in a design is a completely different question (hint: inside an FPGA or CPLD the answer is almost always a solid 'no'). In an ASIC, or other device where maybe there is an SR latch primitive the answer can be 'yes'.
Kevin Jennings
I've seen this code in an asychronous CPLD design...
There is no such thing as a "transparent SR latch".
"transparent latch" and "SR latch" are different, but both have combinatorial feedback.
An "SR latch" can be implemented with a D-flip-flop if you only use the "set" and "clear" inputs.
You can not implement a "transparent latch" with a D-flip-flop.
Outside of the declared processes, each assignment is it's own process.
Reactions: shaiko
    shaiko
