sushma67
Junior Member level 1
i dnt know how to do looping in vhdl help me.......... code for exponent determinant using piposhiftr and decrementer
00100101 is given as i/p to pipo shifter max power of msb is 7 is given as i/p to the decrementer first 0 is shifted it should decerment to 6 secnd bit also 0 so again it should dec if 1 comes it should stp dec and shifting and tho o/p is 5
please see the block diagram below.............
untill 1 comes the loop should continue.....
library IEEE;
use IEEE.STD_LOGIC_1164.all;
entity pipo is
port(
clk : in STD_LOGIC;
pr,cr: in std_logic;
d : in STD_LOGIC_VECTOR(3 downto 0);
q : out STD_LOGIC_VECTOR(3 downto 0);s: in out std_logic_vector(3 downto 0));
end pipo;
architecture pipo of pipo is
begin
process( d,clk)
BEGIN
t:=s;
while(d(0)!='1')
if(pr='1' and cr='1' and clk='0' and clk'event)then
q(0)<=d(0);
q(1)<=d(1);
q(2)<=d(2);
q(3)<= d(3);
elsif(pr='1' and cr='0')then
q(0)<='0';
q(1)<='0';
q(2)<='0';
q(3)<= '0';
elsif(pr='0' and cr='1')then
q(0)<='1';
q(1)<='1';
q(2)<='1';
q(3)='1;'
elsif(pr='0' and cr='0')then
q(0)<='X';
q(1)<='X';
q(2)<='X';
q(3)<= 'X';
t:=t+"1111";
end if;
end loop;
s<=t;
end process;
end pipo;
library IEEE;
entity pipo is
port(
clk : in STD_LOGIC;
end pipo;
begin
process( d,clk)
BEGIN
t:=s;
while(d(0)!='1')
q(0)<=d(0);
q(1)<=d(1);
q(2)<=d(2);
q(3)<= d(3);
q(0)<='0';
q(1)<='0';
q(2)<='0';
q(3)<= '0';
q(0)<='1';
q(1)<='1';
q(2)<='1';
q(3)='1;'
q(0)<='X';
q(1)<='X';
q(2)<='X';
q(3)<= 'X';
t:=t+"1111";
end if;
end loop;
s<=t;
end process;
end pipo;
