VHDL code for IR Transceiver input into 7 segment display
bared
Newbie
Title probably sounds confusing.
Is it possible to get "data" from an infrared signal (from a remote controller) and display it on a 7-segment display on ALTERA FPGA board? If so, can I have a small example
of the VHDL code? Do I have to do anything extra other than code it and adding it to the board?
Sorry if it's simple or not, I'm kind of new to this! I did try to search for specifics but infrared is really hard to come by.
library ieee;
use ieee.std_logic_1164.all;
entity rc5 is
port( clk :in std_logic; -- Clock signal
rst :in std_logic; -- Low logic reset
rd :in std_logic; -- Low logic read
wr :in std_logic; -- Low logic write
cs :in std_logic; -- Low logic chip select
rc5 :in std_logic; -- infrared data input
addr :in std_logic_vector(1 downto 0); -- Address bus input
data_in :in std_logic_vector(7 downto 0); -- Data bus input
data_out:eek:ut std_logic_vector(7 downto 0); -- output
int :eek:ut std_logic); -- Low logic interrupt output
end entity;
This is something I found while searching, I assume I have to use rc5 as input? Then how do I display it to a 7 segment display as output?
LaTeX Commands Quick-Menu:
