Register Log in
VHDL code for complex arithmetics
vijayalaxmi
Newbie level 1
i want to know a synthesizable code to find the value of....
for eg. x to the power of y , where x is an integer and y is a real number ,like
2 to the power of 0.5.
i tried with ** operator,like defining x and y as integer and real data types respectively and z as areal data type .given the exp. z<="**"(x,y),
where "**" is a predefined function in math_real package in ieee library.
but real data types are not synthesizable.
so,plz someone help me in this regard.
aajizattari
Member level 3
vhdl code
i TOO am a beginner here but
I think one possible way to step forward is
looking into FIXED POINT ARITHMETIC
May be you can get approximate solutions
echo47
Advanced Member level 5
USA
vhdl code
Also check the libraries and cores provided with your synthesis software. It may contain floating point math modules that you can drop into your project.
avimit
Banned
Fleet, UK
Re: vhdl code
Dear vijayalaxmi,
What you are trying to do isn't possible. This is because the synthesis flow is not mature enough to cater for this kind of complex arithmatic.
So, you need to see what 'y' is, then build a customised block for finding x**y, may be you will have to use a rom if range of x is limited, and store the values of x**y in rom.
For example in mp3 decoding you need to find z=x**(4/3) so I had do to a customized block to implement that, where I store some values in ROM, and the rest was a linear interpolation.
Hope it helps
Kr,
Avi
http://www.vlsiip.com
suru
Full Member level 3
vhdl code
i need vhdl code of turbo code. plz help me to get it.
vinodkumar
Full Member level 5
hyderabad
Re: vhdl code
hi,is this operation required every time or its required only once.and also the power is multiple of 2 or anything else.
Toggle Sidebar
