vhdl code and Xilinx SRAM-based FPGA
lahrach
Full Member level 3
hi friends,
----------------------------------- the example------------------------
memory_enable_lut: LUT4
generic map (INIT => X"8000")
port map( I0 => t_state,
I1 => instruction(13),
I2 => instruction(14),
I3 => memory_write,
O => memory_enable );
in this example is LUT4 is known for ISE as a component without defining it, or should I define it
regards :-D
alexan_e
Administrator
Greece
Check the examples in the attached link, there are examples how to use it
Alex
