nusyil
Newbie
Hi all !!
When i try to write to 16x2 44780 based LCD, i've encountered very strange problem. When i try to write to LCD " FM 89.1 Mhz" there is no problem, works perfectly.
But, if i try to write " FM 89.0 Mhz" there is nothing on the screen !! zero after dot doesn't work!! however 1,2 etc,after dot works.
My controller is AT89C52. I tried all in ISIS, not real life. My codes are below.
Any suggestions?
Thanks in advance.
Any suggestions?
Thanks in advance.
Code ASM - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 $mod51 $nosymbols org 0000h ljmp mainprogram org 0100h mainprogram: ;%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% ; example: Delay 50 provides 50 msn delay delay macro carpan local den mov r3,#carpan den: Mov tmod,#1 mov tl0,#66h ;lower byte mov th0,#0fch ;upper byte setb tr0 jnb tf0,$ clr tf0 djnz r3,den endm ;%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% ;======================================================================== ; definitions ;======================================================================== rs bit p1.0 rw bit p1.1 en bit p1.2 command equ 52h port equ p0 ; lcd port lines connected to p0 ;======================================================================= ; initialization ;======================================================================= mov p0,#0 mov p1,#0 ;======================================================================= ; main program ;======================================================================= mensage: Db 'fm 89.0Mhz',99h lcall init_lcd mov dptr,#mensage don: Mov a,#0 movc a,@a+dptr cjne a,#99h,continue jmp $ continue: Lcall write_text inc dptr jmp don ;======================================================================== init_lcd: Clr rs clr rw clr en setb en mov port,#28h clr en delay 1 mov a,#28h ; function set lcall write_2_nibbles delay 1 mov a,#0eh ; display on-off kontrol lcall write_2_nibbles delay 1 mov a,#06h ; entry mode set lcall write_2_nibbles delay 1 mov a,#80h ; ddram adres select lcall write_2_nibbles delay 1 ret ;======================================================================== write_2_nibbles: ; write a as two separate nibbles to lcd mov command,a orl a,#0fh mov port,a setb en clr en mov a,command orl a,#0f0h swap a mov port,a setb en clr en ret ;======================================================================== clear_lcd: Clr rs mov a,#01h lcall write_2_nibbles delay 5 ret ;======================================================================== write_text: Setb rs lcall write_2_nibbles delay 5 ret ;======================================================================== end
