Vertix configuration error: cable connection failed
Naz
Junior Member level 1
I am using Vertix XCV50 (XESS BOARD V1.1) ,on configuring the device i get an error of "CABLE CONNECTION FAILED",What should i do in order to configure the device?
vivek
Member level 4
Re: VERTIX CONFIGURATION
hi
make sure that you are using the right cable. if u are using IMPACT then right
click and select 'cable auto detect'. this should automatically detect your cable.
u can refer to the IMPACT help documentation for details and troubleshooting
vitus1974
Newbie level 1
You must ensure that You have only one impact window and no one programm not open port for it's use. Next try to use last version of software...
Good Lack
