bhl777
Full Member level 6
- Joined
- Sep 30, 2008
- Messages
- 363
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,296
- Activity points
- 5,140
The only way for a diode as drawn in your schematic I can imagine would be a second (separate) n-well guardRing with n+ diff contacts surrounding the VPNP's n-well - and, possibly, also the VPNP's collector p+ substrate contacts. In this case its cathode pin (n+ diff) should be connected to the highest positive potential (probably VDD). But of course its anode connection shouldn't point to the base but to the collector of the VPNP = substrate connection.
This construction also would implicate a parasitic lateral NPN, which is totally off, however. Would be nice to see the layout.
I also saw another kind of vpnp from Cadence, like attached. The parasitic diode symbol has different direction. Is this one will be connected exactly the same as the one I showed at the beginning? Thank you very much! View attachment 89910
Yes, I think it's also an n-well guardRing diode surrounding the VPNP. Same connections as above, then. But as the pins are crossed out, I think the connections are handled automatically. Could you provide a layout image?
Is there any way to search for their layout?
