But it's still quite unclear to me. I more or less understand reg as a variable like in C, and since I can route this
variable to the output, why should I bother with wires? That's basically my concern right now.
The webpage above says that regs might not be synthesizable. What does it mean?
It can be synthesized to FF -> What does it mean?
Can I consider that a reg is a wire with memory capability?
Can I always make an all-reg program, without wires?
Until now, I have used only regs, but is there a disadvantage of using only regs? Maybe it consumes memory?
If anybody could give me examples of programs I cannot do with regs, it would probably help.
the names are based on how they relate to simulation, which is confusing. It has nothing to do with synthesis. reg is used when assigned in an always block, wire otherwise.
system verilog added a "logic" type to reduce the confusion.
It has nothing to do with synthesis so what does the above webpage mean by "regs might not be synthesizable"?
And also It can be synthetized to FF?
And is it always possible to make a design without wires, with only regs? I mean, I did as explained in another
post, so it's possible, but is it always possible in any case?
A reg used inside an always block leads to the inference of a flop. You use it when you are defining sequential logic.
When you are writing RTL for combinatorial logic, something outside the always block, use wire. Think of wire such as simply connecting one electrical point to another.
Please read a good Verilog book, a real book, to clear fundamentals rather than relying on various web sources.
Thanks for your reply. I'm waiting for the books ordered earlier this week. On Verilog, VHDL and System Verilog.
I just wanted to do some experiments in the meantime...
Small pieces of code yes (module output ports must be connected to a wire) because the choice is a syntax choice and often not a consequential design choice. Reg's may synthesize to wires or reg's depending on how you actually used them.
So if it's in a begin/end block -> reg
If not -> wire
In general you don't use reg unless there is a reason though there are a couple good reasons:
1) It's actually a reg assigned in an always @(posedge x) block
2) You want access to syntax that only applies to reg's, such as if/then/else or case
If the above doesn't apply leave it a wire because while a reg has ambiguity a wire does not.
reg comes with "<=" inside always block
wires comes with "=" (my hint: outside always blocks, altough "=" is accepted by Verilog inside always blocks)
Bonus: I prefer to use uses only clocks into always blocks "e.g.: always (posedge CLK)" and let all the combinational logic (without clocks) outside always. For example:
I suspect this might just mean that you could write code in always blocks that the synthesis tool won't synthesize. For example, tools will not synthesize while loops except in very specific cases. a "reg" described by assignments in a while loop might not be possible to represent by any circuit. This is especially clear if the while loop never terminates for some input combination.
