femystika08
Newbie level 5
- Joined
- Dec 10, 2012
- Messages
- 8
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,330
I recently translated a code from verilog to vhdl and got some syntax errors.
verilog code
vhdl code
I get these errors when I run the vhdl code
I don't understand why arithmetic operations are not allowed here.
Thanks in advance for any suggestions.
verilog code
`timescale 1ns/10ps
module dct_mac(
clk,
ena,
dclr,
din,
coef,
result
parameter dwidth = 8;
parameter cwidth = 16;
parameter mwidth = dwidth + cwidth;
parameter rwidth = mwidth +3;
input clk;
input ena;
input dclr;
input [dwidth-1:0] din;
input [cwidth-1:0] coef;
output [rwidth-1:0] result;
reg [rwidth -1:0] result;
wire [mwidth-1:0] idin;
wire [mwidth-1:0] icoef;
reg [mwidth -1:0] mult_res ;
wire [rwidth -1:0] ext_mult_res;
assign icoef = { {(mwidth-cwidth){coef[cwidth-1]}}, coef};
assign idin = { {(mwidth-dwidth){din[dwidth-1]}}, din};
always @(posedge clk)
begin
if(ena)
mult_res<=icoef * idin;
end
assign ext_mult_res = { {3{mult_res[mwidth-1]}}, mult_res};
begin
if(ena)
begin
if(dclr)
result<=ext_mult_res;
else
result<=ext_mult_res + result;
end
end
endmodule
vhdl code
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_misc.all;
use ieee.numeric_std.all;
--use ieee.std_logic_arith.all;
entity dct_mac is
generic (
dwidth : INTEGER := 8 ;
cwidth : INTEGER := 16 ;
mwidth : INTEGER := 24 ;
rwidth : INTEGER := 27
port (
clk : in std_logic;
ena : in std_logic;
dclr : in std_logic;
din : in std_logic_vector( ( dwidth - 1 ) downto 0 );
coef : in std_logic_vector( ( cwidth - 1 ) downto 0 );
result : out std_logic_vector( ( rwidth - 1 ) downto 0 )
end dct_mac;
architecture rtl of dct_mac is
signal idin : std_logic_vector( ( mwidth - 1 ) downto 0 );
signal icoef : std_logic_vector( ( mwidth - 1 ) downto 0 );
signal mult_res : std_logic_vector( ( mwidth - 1 ) downto 0 );
signal ext_mult_res : std_logic_vector( ( rwidth - 1 ) downto 0 );
begin
icoef <= ( ( coef(( cwidth - 1 ) ) & coef(( cwidth - 1 ) ) & coef(( cwidth - 1 ) ) & coef(( cwidth - 1 ) ) & coef(( cwidth - 1 ) ) & coef(( cwidth - 1 ) ) & coef(( cwidth - 1 ) ) & coef(( cwidth - 1 ) ) ) & coef );
idin <= ( ( din(( dwidth - 1 ) ) & din(( dwidth - 1 ) ) & din(( dwidth - 1 ) ) & din(( dwidth - 1 ) ) & din(( dwidth - 1 ) ) & din(( dwidth - 1 ) ) & din(( dwidth - 1 ) ) & din(( dwidth - 1 ) ) & din(( dwidth - 1 ) ) & din(( dwidth - 1 ) ) & din(( dwidth - 1 ) ) & din(( dwidth - 1 ) ) & din(( dwidth - 1 ) ) & din(( dwidth - 1 ) ) & din(( dwidth - 1 ) ) & din(( dwidth - 1 ) ) ) & din );
process
begin
wait until ( clk'EVENT and ( clk = '1' ) ) ;
if ( ena = '1' ) then
mult_res <= ( icoef * idin) ; -- error
end if;
end process;
ext_mult_res <= ( ( mult_res(( mwidth - 1 ) ) & mult_res(( mwidth - 1 ) ) & mult_res(( mwidth - 1 ) ) ) & mult_res );
process
begin
if ( dclr = '1' ) then
result <= ext_mult_res;
else
result <= ( ext_mult_res + result) ; -- error
end if;
end if;
end process;
end rtl;
Line 66. * can not have such operands in this context.
Line 77. + can not have such operands in this context.
