Verilog: push button starts sequence
whitexlion
Newbie level 1
Newbie level 1
Hey guys, I was wondering if I could get some help on something I'm working on. I'm very new to Verilog, so I'm not really the best / most efficient at it. I'm trying to get a counter to start counting down when a push button is pressed. I currently have it so that when I press and hold the button, it counts, but when I release it, the counter the stops counting down. Here's the code that I have so far. (I'm using a Nexys2 Spartan3E board)
`timescale 1ns / 1ps
module countonpb(
    input clock, pb,
    output reg [3:0] msbs,
    output reg [3:0] lsbs,
    output reg [6:0] sevseg,
    output reg [3:0] an,
	 output reg [1:0] clk
	reg [3:0] i;
	reg [3:0] j;
	integer count_a = 0;
	integer count_50M = 0;
	reg pb_press;
	initial begin
		an[0] <= 0;
		an[1] <= 1;
		an[2] <= 1;
		an[3] <= 1;
		i <= 9;
		j <= 9;
	end
	always @ (posedge clk[0])
	begin
		an[0] <= ~an[0];
		an[1] <= ~an[1];
		an[2] <= 1;
		an[3] <= 1;
		msbs <= i;
		lsbs <= j;
	end
	always @ (posedge clk[1])
	begin
		pb_press <= pb;
		if (pb_press == 1)
		begin
			if (i == 0)
			begin
				i = 0;
				j = j - 1;
			end
			else
			begin
				if (j == 0)
				begin
					i = i - 1;
					j = 9;
				end
				else
					j = j - 1;
			end
		end
	end
	begin
	if (an[1])
	begin
		case(msbs)
			0: sevseg = 7'b0000001;
			1: sevseg = 7'b1001111;
			2: sevseg = 7'b0010010;
			3: sevseg = 7'b0000110;
			4: sevseg = 7'b1001100;
			5: sevseg = 7'b0100100;
			6: sevseg = 7'b0100000;
			7: sevseg = 7'b0001101;
			8: sevseg = 7'b0000000;
			9: sevseg = 7'b0000100;
			default: sevseg = 7'b0000001;
		endcase
	end
	if (an[0])
	begin
		case(lsbs)
		endcase
	end
	end
	always @ (posedge clock) //slower clock
		if (count_50M < 25000000) count_50M = count_50M + 1;
		else
		begin
				clk[1] = ~clk[1];
				count_50M = 0;
		end
	always @ (posedge clock) //slow clock
		if (count_a < 25000) count_a = count_a + 1;
		else
		begin
			clk[0] = ~clk[0];
			count_a = 0;
		end
endmodule
I was thinking of possibly making a different module for the counting, and just activate that when the button is pressed once.
When I do get the program counting down on button press, I also will have a statement to set a variable to 1 when a certain input is entered on the switches, so I was wondering if I can lock out the switch inputs while the counter is not counting down.
Thanks in advance.
