[VERILOG] How to generate FIFO WRITE SIGNAL in COUNTER MODULE ?
AbinayaSivam
Member level 1
My normal counter code
module counter
	input clk, enable, rst_n,
	output  reg[31:0] count
	always @ (posedge clk or negedge rst_n)
	begin
		if (~rst_n)
			count <= 0;
		else if (enable == 1'b1)
			count <= count + 1;
	end
endmodule
I am trying to implement the above code in Quartus and NIOS.
counter's clock speed is 50MHz, So counter data is missing in NIOS console.
So i need to give control to FIFO (write signal) through VERILOG.
I need to change my counter design to check whether the fifo is full or not and only write the value (and increment the counter) when the fifo is not full. Please suggest me ,
Depends on the design.
The write signal can be always '1', toggling with the clock, toggling at specific intervals, etc. This depends heavily on the nature of the write side of the FIFO.
If you are using the FIFO IP, then the FIFO full flag is already there to be used.
Thanks for your response. I am working with ALTERA quartus software tool.
Simple Counter with FIFO is working. Working Design flow as mentioned (screenshot) as below
module counter
	begin
		if (~rst_n)
			count <= 0;
			count <= count + 1;
	end
endmodule
The above design is working (generated only counter data). In the following design, i have done some modification, in verilog code i am generating Trigger and counter data.
module Counter(
    input clk,
	 input enable,
    input reset,
    output reg[31:0] Final_value,
    output reg trig
    reg[31:0] counter_out;
    reg [7:0] temp;
    reg [31:0] counter_result;
    wire temp1;
    wire temp2;
    always@(posedge clk or negedge reset)
    begin
    if(~reset)
        begin
        trig<=0;
        temp<=0;
        counter_out<=0;
        end
    else if(enable==1'b1)
        begin
        counter_out<=counter_out+1;
        temp<=temp+1;
        if(temp==25)
            begin
            temp<=0;
            trig<=~trig;
            end
        end
        end
	 assign temp1=trig;
	 assign temp2=temp1&&clk;
	 always@(posedge temp2 or negedge reset)
	 if(~reset)
	    counter_result<=0;
	  else
	 begin
        counter_result<=counter_result+1;
     end
  always@(posedge trig or negedge reset)
  if(~reset)
       Final_value<=0;
   else
  begin
       Final_value<=counter_result;
  end
endmodule
Can anyone check my design. Whether i doing right or wrong.
