[SOLVED] Verilog Error
Div_01
`timescale 1ns / 1ps
`default_nettype none
// for SPI MODE 3
module spi_msg #( parameter nrRWregs = 4,
                   parameter nrROregs = 12 ) // nrRWregs + nrROregs should be <= 16
                ( input wire sysClk,        // FPGA system clock (must be several times faster as SCLK, e.g. 66MHz)
                  input wire usrReset,      // FPGA user reset button
                       input wire SCLK,          // SPI clock (e.g. 4 MHz)
                          input wire MOSI,          // SPI master out, slave in
                        output wire MISO,         // SPI slave in, master out
                        input wire SS,            // SPI slave select
                        output wire [1:0] LED );  // debug
   wire rxValid;
    wire [7:0] rx, tx;
    wire [nrRWregs*32-1:0] rwRegs1D;
    wire [nrROregs*32-1:0] roRegs1D;
     // bits <> bytes
   spi_byte_if byte_if( .sysClk  (sysClk),
                                .usrReset(usrReset),
                         .SCLK    (SCLK),
                                .MOSI    (MOSI),
                                .MISO    (MISO),
                                .SS      (SS),
                                .rxValid (rxValid),
                                .rx      (rx),
                                .tx      (tx) );
   // bytes <> messages
   spi_msg_if #( nrRWregs, nrROregs ) msg_if
                    ( .sysClk  (sysClk),
                      .rxValid (rxValid),
                  .rx      (rx),
                  .tx      (tx),
                 .rwRegs1D(rwRegs1D),
                      .roRegs1D(roRegs1D) );
    // inflate the 1D arrays (rwRegs1D, roRegs1D)
    // into a 2D registers array (registers)
    wire [31:0] registers[0:nrRWregs+nrROregs-1];
    genvar nn;
    for ( nn = 0; nn < nrRWregs; nn = nn + 1 )
        begin :nnRW
            assign registers[nn] = rwRegs1D[32*nn+31:32*nn];
       end
    for ( nn = 0; nn < nrROregs; nn = nn + 1 )
       begin :nnRO
             assign roRegs1D[32*nn+31:32*nn] = registers[nn+nrRWregs];
       end
    // connect the input and outputs
    assign registers[4] = 32'hDEADBEEF;
    for (nn = 1; nn < nrROregs; nn = nn + 1 )
        begin :nnRegs
             assign registers[nn+nrRWregs] = 32'h00000000;
       end
    // turn LEDs on when expected value has been written to register
    assign LED[0] = (registers[0] == 32'h76543210 );
    assign LED[1] = (registers[1] == 32'h01234567 );
endmodule
ERROR:HDLCompilers:26 - "spi_msg.v" line 45 expecting 'endmodule', found 'for'
Can someone help me with this syntax error? I don't understand why the code is throwing an error.
Thanks & Regards,
Divya
