abimann
Member level 4
Verilog error , Pls help
I want to say thank you for guys which is always help me and others, and spent their time, based on this our world going to be better.
I am know nothing in Verilog, here should be problem related to FPGA chip, because when i change to Virtex-4 from Spartan-6, there always error not declared :
But when I change to Spartan-6 thats ok. Could someone tell me what to do ?
This project taken from https://github.com/zafartahirov/background_subtract_XILINX
ERROR:HDLCompilers:28 - "TestCapture.v" line 26 'real_data' has not been declared
ERROR:HDLCompilers:28 - "TestCapture.v" line 27 'pixel_fg' has not been declared
`timescale 1ns / 1ps
`define IDLE 0
`define WAIT_4_NEW_FRAME 1
`define RECORD_IMAGE 2
`define PROCESS_IMAGE 3
module test_buffer(
input [4:0] pixel_in,
output [4:0] pixel_out,
input [30:0] hCounter_in,
input [30:0] vCounter_in,
input clk
wire [4:0] pixel_temp;
wire blank_bg, blank_fg, blank_real;
assign blank_bg = (hCounter_in >= 640 | vCounter_in >= 480);
assign blank_real = hCounter_in < 170 | hCounter_in >= 330 | vCounter_in >= 140;
assign blank_fg = hCounter_in < 340 | hCounter_in >= 500 | vCounter_in >= 140;
assign pixel_out = ( {16{~blank_bg}} & pixel_temp ) |
( {5{~blank_real}} & real_data ) |
( {5{~blank_fg}} & {5{pixel_fg}} );
reg [14:0] counter_address, counter_address_real, counter_address_fg;
reg wea = 1;
reg [12:0] proc_d; // processed data from BRAM
wire [14:0] addr_write = (counter_address==0)? 22399: counter_address-2; // computes the address of the BRAM
reg [12:0]temp_bg; // computed background (going to the BRAM)
reg [4:0] temp_real; // input from the camera
reg [4:0] real_data; // output of the camera feed
reg temp_fg; // the difference (goes to the BRAM)
reg pixel_fg; // the difference for foreground detection
wire [4:0] difference;
assign pixel_temp={temp_bg[11:7]}; // background output pixel
assign difference[4:0] = (temp_real[4:0] > pixel_temp[4:0]) ?
(temp_real[4:0] - pixel_temp[4:0]) :
(pixel_temp[4:0] - temp_real[4:0]);
always @(posedge clk) begin
// compute the current address for the BG detection
// as well as real feed
if (~blank_bg) counter_address <= counter_address+1;
if (counter_address >= 22399) counter_address <= 0;
if (~blank_real) counter_address_real <= counter_address_real+1;
if (counter_address_real >= 22399) counter_address_real <= 0;
if (~blank_fg) counter_address_fg <= counter_address_fg+1;
if (counter_address_fg >= 22399) counter_address_fg <= 0;
end
always @ (posedge clk) begin
if (~blank_bg) begin
temp_bg[12:0] = proc_d[12:0] - proc_d[12:7] + pixel_in[4:0];
temp_real = pixel_in;
temp_fg =(difference[4:0] > 5);
end
end
//stores computed background
buffer_data1 buffer_data (
.clka(clk),
.wea(wea),
.addra(addr_write),
.dina(temp_bg),
.clkb(clk),
.addrb(counter_address),
.doutb(proc_d)
// stores real feed
bram_current_frame buffer_data_real(
.clka(clk),
.wea(wea),
.addra(addr_write),
.dina(temp_real),
.clkb(clk),
.addrb(counter_address_real),
.doutb(real_data)
// stores the difference frame
bram_fg buffer_data_fg(
.clka(clk),
.wea(wea),
.addra(addr_write),
.dina(temp_fg),
.clkb(clk),
.addrb(counter_address_fg),
.doutb(pixel_fg)
endmodule
